Author Topic: Seeking A/C compressor bracket to replace “monster bracket”.  (Read 4124 times)
Scope9
I have been hunting in vain for a sedan A/C bracket to move a new compressor up top.  Found one on eBay but when I received it I found the end that mounts to the intake manifold is different than the examples I have seen posted on the forum.
Could sure use some advice on where I might locate a correct one.
m300cab
  • USA, Pennington New Jersey
then your alternator will  be low.
if your in a thunderstorm with flooding your car will stall.
good to keep your alternator high away from the ground
Michael Parlato
dirkbalter
  • USA, CA, Corona
@ Michael, "It never rains in Southern California"  8)
Scope,
I have a 108 with the AC bracket you are probably talking about. What exactly are you looking for? I am also integrating AC into the 113 using the buds benz kit. What type of compressor are you using?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: Seeking A/C compressor bracket to replace “monster bracket”.
« Reply #3 on: September 08, 2021, 22:44:53 »
You will also need the thermostat neck as the sedan one is taller than the Pagoda one.
