Author Topic: diaggram of the 6-way USA switch  (Read 3921 times)
« on: July 19, 2021, 18:54:50 »
I’m looking for the diagram of the 6-way switch - USA version see below.
I found on the forum the 4-way diagram, but the USA version is 6 way.
Does somone has the diaggram of the 6-way USA switch.
Thanks Peter
edwardburak@erols.com
  • USA, VA, Marshall
Re: diaggram of the 6-way USA switch
« Reply #1 on: July 19, 2021, 19:50:44 »
I can send a picture of my switch with the wires exposed if you would like
WRe
« Reply #2 on: July 19, 2021, 20:08:48 »
see att. picture.
...WRe
« Reply #3 on: July 19, 2021, 20:17:58 »
That would be very halpfull, thanks.
« Reply #4 on: July 19, 2021, 20:20:52 »
see att. picture.
In the 6-way, I see only 4 connections. What do the other two do?
lpeterssen
  • USA, FL, Miami
« Reply #5 on: July 20, 2021, 11:20:42 »
Put your switch on each of the positions and observe with a multimeter connected to the two unknown function post when do they have continuity.  Let’s do some Sherlock Holmes investigation on them  to find out the answer.
WRe
« Reply #6 on: July 20, 2021, 12:01:25 »
according to the wiring diagram, only 4 poles are connected and must be plugged in accordingly*:
1.) From fuse 5 black-yellow-red cable 0.75  mm²
2.) To ignition starter switch violet-white 2.5  mm²
3.) To reverse light gray-yellow 0.75  mm²
4.) To starter terminal 50 violet 2.5 mm²
...WRe
*https://www.sl113.org/wiki/Electrical/Connectors
« Last Edit: July 20, 2021, 14:18:49 by WRe »
mnahon
  • Canada, QC, Montreal
« Reply #7 on: July 20, 2021, 12:33:45 »
Peter, if your car has a 6-way switch, you could open the plug to see if those last two sockets have any wires connected to them.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #8 on: July 20, 2021, 19:43:51 »
It has 6 connectors, see picture below, no time today to do more research, I hope Saturday.
lpeterssen
  • USA, FL, Miami
« Reply #9 on: July 20, 2021, 20:29:29 »
Peter:
The two bottom cables, un-identified so far seem to be one light green and the other green with a white stripe.
Peter please confirm the colors to look at the BBB And other electrical manuals I have on hand to discover what for are they….
Best regards
Leonardo Peterssen
lpeterssen
  • USA, FL, Miami
« Reply #10 on: July 20, 2021, 20:48:58 »
Found the answer
Look at the attached picture from a MB Electrical manual.
The two until now Un-identified cables are related to the kick-down switch lacing, to be sure the car is in DRIVE to activate the kick down.
Pin 107 cable black red green feed wire from fuse 3 on automatic cars
Pin  119 green cable going to the kick down switch feed side, from there to the transmission selenoid.
Best regards
L.peterssen
« Reply #11 on: July 21, 2021, 08:39:29 »
Dear Gents,
My car is a 280SL/8 1969 (USA version) with “emission control”.
Below the 6-way connector with wire colors
• The two green wires on the left are from the shut of solenoid on the Fuel Injection Pump.
• The others I will check later. But most probably they are what WRe has in his drawing.
• Question: The “anlass sperrcontact” is preventing starting in any position expect P?
« Reply #12 on: July 21, 2021, 10:35:49 »
Any position except P and N.
WRe
« Reply #13 on: July 21, 2021, 14:31:48 »
if you look in my document that describes the functions of all complementary components of the Emission Control System
https://www.sl113.org/wiki/Electrical/EmissionControlSystem
you'll find on page 4 the two additional connections from the 6-way Start Lock Switch (14) one to the Speed Relay (4) and one via a cable connector (27) to the Idle Throttle Switch (15) if I don't have an optical deflection.
...WRe
« Last Edit: July 21, 2021, 14:40:33 by WRe »
« Reply #14 on: July 21, 2021, 16:19:58 »
I have an Emission control system 280SL USA 1968/1969 – not 70/71.
below the overview:
“6 - the micro switch” and “7 - the fuel cut off solenoid” are connected via green wires which run via the 6-way connector and switch.
  • USA, VA, Marshall
« Reply #15 on: July 21, 2021, 20:53:55 »
this is what I have on my 1969 280sl automatic.
the small wire in the upper center position looks to be another grey/yellow wire but is actually a black wire with red stripe.
« Reply #16 on: July 25, 2021, 17:46:02 »
for the sake of completeness and with thanks for the drawing to WRe.
