Author Topic: 1969 280sl wiring help  (Read 4621 times)
edwardburak@erols.com
  • USA, VA, Marshall
« on: July 21, 2021, 21:07:39 »
 1969 mercedes 280SL USA Version automatic
I'm having some trouble installing some of the wiring for the motor. This motor is not original to the car, I am not sure of the year car it was taken out of. I bought the motor from budz-benz 10 years ago and am now installing it.
I have this 3-wire harness coming off of the main harness from the firewall on the driver's side (USA Version). It has one longer single wire which reaches the 100 degree advance on the thermostat and 2 wires that reach a connector above the injector station.
I realize that the connectors are the wrong type, my car does not have those round connectors as found on other cars, maybe someone altered it in the past.
are these the correct locations for these wires?
If so, I will try and source the correct connector to splice into these wires
thanks for your help
  • USA, VA, Marshall
Re: 1969 280sl wiring help
« Reply #1 on: July 21, 2021, 21:17:20 »
I also have this connector on the side of the throttle body, I do not know what it is called.
Are my wires on this connector correct. they also stem from the larger loom, coming from the firewall.
This was the logical location with the bends in both the connectors and the wires
  • USA, VA, Marshall
« Reply #2 on: July 21, 2021, 21:23:16 »
another connection that I am unsure if I have correct is the solenoid or relay beside the fuel throttle linkage overtop the intake.
my placement of these wires on this connector was also a use of the process of elimination and a reasonable location.
I have not found another location that these wires could go
the near side wire is green and the far side is black with a red stripe.
Are my guesses correct?
if not, any help would be appreciated
thanks
  • USA, VA, Marshall
« Reply #3 on: July 21, 2021, 21:26:05 »
I have this fuse box on the passenger side (USA Version) beside the radiator overthrow reservoir.
I have wires that are dangling and I assume go here; I have not been able to find a diagram on it, could someone please send a photo of theirs with the wires exposed and I will make the correction my own.
thanks for the help.
  • USA, VA, Marshall
« Reply #4 on: July 21, 2021, 21:29:01 »
this is my last issue, I have another fuse box on the driver's side beside the brake booster.
am I missing something in this box?
or is the extra slot just for modifications and additions?
thanks for the help
« Reply #5 on: July 22, 2021, 07:40:35 »
Let me give it a stub.
1. Fuse box on the passenger side, near the voltage regulator - is for the radio and the power antenna if you have it. Two wires may be coming out of the harness there - one with permanent power (antenna), one with power with ignition key in accessory position. They go through the fuse and then to the radio/antenna through a grommet in the firewall. You will find more when you search "radio wiring".
2. Fuse box near the brake booster - accessory fuse box. Designated primarily to fog lamps, but may serve many purposes (e.g. I have the dashcam power through it). Two slots for fuses - fill them as per needs. You have something hooked there, not sure what it could be.
3. Constant speed solenoid connection - the green or red/green wire is ground from hydraulic switches on the gear box sides. Provides ground when gear is engaged to make this solenoid move the linkage by about 5mm to increase idle when in gear to prevent engine from stalling. On late US cars this solenoid is for increasing idle when AC is switched on and is hooked to the AC, not gear box. On some cars it is not connected to anything. The other wire is, logically, +. From fuse 5.
4. The throttle switch - provides power to the 3 way solenoid on the gear box to make it in the upshift mode as you press the gas pedal. Red/black wire is + from fuse 3, brown/white wire goes to 3 way solenoid.
  • USA, VA, Marshall
« Reply #6 on: July 22, 2021, 10:22:16 »
thank you, I will check that my wires are correct
lpeterssen
  • USA, FL, Miami
« Reply #7 on: July 22, 2021, 11:46:51 »
Dear Edward
You need a lot of help.  Go to the technical section of the pagoda forum and study the wiring diagram for pagoda 280SL.
I will try to guide you the best. Let’s do one or two related pictures at a time.
The first will be the TTS or also called Thermo Time Switch.  This device has two terminals one labeled “W” and another labeled “G”. I saw the pictures taken, and that the engine already has a modern style TTS which requires you to change the “0” shaped terminals of your cables for a modern style connector, or some aftermarket terminals I will show you the picture as well.
Here you have to be very careful with the connections since you can cause a very nasty short since this lines are one a positive signal and the other a negative. If you invert them you will have a short remember.
“G” terminal is positive and comes on the cable ROSE/blue and derives from the ignition switch T50 cranking signal.
“W”  is negative and is the trigger signal that activates the different cold start relay and mixture relay on the left fender close to vacuum booster.  That cable is ROSE.
SEE pictures.
« Last Edit: July 22, 2021, 12:41:09 by lpeterssen »
lpeterssen
  • USA, FL, Miami
« Reply #8 on: July 22, 2021, 11:56:07 »
This are the kind of terminals you need to put on the TTS cable ends.  Is much cheaper to change the terminals than buying a new original style TTS .  Old style TTS are about 300 usd.
lpeterssen
  • USA, FL, Miami
« Reply #9 on: July 22, 2021, 12:01:50 »
Now on the same loom that goes to the TTS there is a single “o” shaped connector which goes to the MIXTURE SELENOID a the back of the fuel injection pump.
Green circle on the photo.
The cable should be Black/rose
lpeterssen
  • USA, FL, Miami
« Reply #10 on: July 22, 2021, 12:12:02 »
Now Edward
Let’s go with the terminals related to the automatic transmission……
There are two elements to remark on your photos.
One is the IDDLE SWITCH which is at the INTAKE THROTTLE which receives two cables. One should be RED/BLACK (+ signal) coming from fuse no.3, and the output wire is BROWN/WHITE also (+) going to the transmission selenoid.
In here the way you connect the cables does not matter, you can invert them and nothing will change since this is only a switch.
Iddle switch is shown as element 52 on the diagram
lpeterssen
  • USA, FL, Miami
« Reply #11 on: July 22, 2021, 12:18:41 »
And finally the Constant Speed Selenoid….l. Also named CSS (element 53 on the chart)
It is fed with two cables.  Order on which you connect them also does not matter.  One is a constant 12V feed from fuse no. 5, which is a cable active whenever ignition is on, Colour BLACK/RED/GREEN.
And the negative activation signal comes from the automatic transmission pressure valve on the cable Colour GREEN/RED.
And that will be all for today….
Hope everything goes fine.
Best regards
Engineer Leonardo Peterssen
lpeterssen
  • USA, FL, Miami
« Reply #12 on: July 22, 2021, 12:22:37 »
Look at the Colour of this cable, not sure if it goes here at this thermocouple…..
  • USA, VA, Marshall
« Reply #13 on: July 29, 2021, 17:06:20 »
Thanks for your help
I decided to purchase a mercedes 2 post female connector and pins. I think I have located my mixture solenoid on the tail end of the injection pump and the bolt to receive my eyelet connector. this wire in black/rose as you described.
I also see the W ang G on my TTS and will carefully make sure to get the correct wire on the correct post.
The only thing left is my thermostat, It has a connector on top but my wiring harness does not have a wire to go to it, I think I will swap it for a standard (no connector thermostat)
thanks once again.
lpeterssen
  • USA, FL, Miami
« Reply #14 on: July 29, 2021, 19:15:17 »
Dear Edward
Do you have air conditioner on your car? Because maybe that thermostat post was to trigger the condenser fan.
And …. What is missing in that case is the wiring harness that controls all the a/c system.
Best regards
Lpeterssen
  • USA, VA, Marshall
« Reply #15 on: July 29, 2021, 19:41:57 »
yes, I have an AC car. I have not yet installed the wiring harness for the AC compressor. I need another thermostat for my second car, do you by chance know the part number for this thermostat with the connection on top?
thank you for your help
lpeterssen
  • USA, FL, Miami
« Reply #16 on: July 29, 2021, 20:06:37 »
No Edward I do not know that part number.
I can produce that wiring harness for the A/c system if needed.
Best regards
L.peterssen
« Reply #17 on: July 29, 2021, 21:32:54 »
I am not good at finding parts related to AC and/or pollution control system, but what I see in the parts list, the 100deg switch (PN A 006 545 36 24, optional with several other PNs) was used for both of these systems. Thermostat part number I found is A 616 200 01 15 (NLA), SA 12213 and 12213/10 ENGINE PARTS W/AIR CONDITIONER ATTACHED
« Last Edit: July 29, 2021, 22:09:45 by Pawel66 »
  • USA, VA, Marshall
« Reply #18 on: July 29, 2021, 23:34:15 »
thanks, I will keep you in mind if I or someone else needs that.
  • USA, VA, Marshall
« Reply #19 on: July 29, 2021, 23:35:42 »
  • USA, VA, Marshall
« Reply #20 on: July 29, 2021, 23:44:17 »
From what I have read, the connection on top pf the thermostat housing is the 100 degree timing advance. But you are saying that in my car it may be for the air conditioning system?
I know that my wiring harness does not have the single round style connector as found on other cars.
I am installing a vintage air AC system as my car is not a stock AC car.
I have not yet installed or inspected the supplemental wiring harness that goes with the ac compressor and controls by the dash.
thanks
lpeterssen
  • USA, FL, Miami
« Reply #21 on: July 30, 2021, 11:23:14 »
Dear Edward
I did not know that particular use of that thermocouple 100 degrees, for the timing advance.
What I am saying is that on an aftermarket  a/c system, or even in some versions of the original one, you may use water temperature switches as the one to trigger the condenser fan in front of the radiator.
The most common approach and the simplest on A/c systems is to trigger the condenser fan each time the compressor ac is engaged.  But I do not like that approach for various technical reasons.
I prefer the approach that Mercedes applied on w100 (grand mercedes) or in the w109-6.3.
In those cars the condenser fan (front of radiator) is triggered by two separated negative signals.  One coming form a water thermocouple switch, generally at 85 degrees Celsius, and the other triggering signal comes from a refrigerant pressure valve, commonly called trinary switch.  In that way you do not stress so much the electrical system adding permanently the load from the condenser fan.  And A/c system consumes  a lot of energy, and many mercedes have original 35 or 55 amps alternators, and the charging loom is calculated for ONLY that current, let’s say 35 or 55 A.
The trinary switch only engages the condenser fan, which is a significant load of 10 to 15 A depending on size only when really needed. When you are driving freely on a highway, the amount of air that passes trough the a/c system and refrigeration (radiator) system is more than adécuate so there is no need to engage the fan, saving power, and redirecting all the energy produced by the alternator to the battery.
When you are IDDLING after a few minutes of being stop, refrigerant pressures rises, and in consequence the fan is triggered.   Once the car starts to move again, air flow may be enough to keeps all the systems happy, so the fan does not engage again.
Finally the water temperature sensor is used to activate the condenser fan in case that water temperature is higher than the set point and the work of the radiator fan clutch is not enough to keep system cool.
Best regards
L.peterssen
« Last Edit: July 30, 2021, 13:06:26 by lpeterssen »
  • USA, VA, Marshall
« Reply #22 on: July 30, 2021, 13:14:48 »
thank you for the clarification and detailed description
