Author Topic: Oil pump - Clearences  (Read 1967 times)
BartSt
  • Belgium, Flanders, Antwerp
« on: July 26, 2021, 10:44:18 »
All,
What is the max clearance on the oil pump.
Between the side and rotor and between rotors?
And if it is to big, can you just change the rotor?
Bart
Re: Oil pump - Clearences
« Reply #1 on: July 26, 2021, 12:08:31 »
Far simpler to mill the housing slightly than source a new set of gears.
BartSt
« Reply #2 on: July 26, 2021, 12:37:37 »
True, but what is "Within Specs"?
BartSt
« Reply #3 on: July 27, 2021, 18:32:48 »
Nobody (knows the specs)
« Reply #4 on: July 27, 2021, 19:56:36 »
According to the technical data book, 1966 edition, for the 230sl oil pump "clearances between oil pump gears and pump housing" are 0.025-0.057 radial, and .050-.092 axial (mm).
BartSt
« Reply #5 on: July 27, 2021, 20:06:27 »
many thanks!
