Author Topic: Heat coming in thru the firewall  (Read 2754 times)
Mohan58
  • Malaysia, Selangor, Petaling Jaya
« on: August 03, 2021, 14:28:17 »
Hi guys,
I notice after a while of driving, i feel a lot of heat around my legs & also my passenger complains about it. We do live in Malaysia & it is hot here(no aircon in car yet). Could it be the insulation that has gone over the years? What are your thoughts please.
Cheers
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Re: Heat coming in thru the firewall
« Reply #1 on: August 03, 2021, 15:58:24 »
There is limited insulation in the leg room. I would check for:
- uncovered, unplugged holes (although not too many of them on passenger side)
- presence of exhaust heat shields
I never drove a Pagoda in a climate like Malian. On a hot day in my area it may feel a bit warm. But if any of the holes is open - much more hot air is coming in.
There are pieces of insulation under dash inside. You may look at SLS site to see what should be there and compare with what you have.
« Reply #2 on: August 04, 2021, 01:36:20 »
Also check underneath to see if you have the exhaust shields in place. Without them the floors will heat up lots.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Harry
  • USA, TN, Knoxville
« Reply #3 on: August 04, 2021, 11:19:16 »
You'll be surprised at the amount of heat (and odors) that snake their way into the passenger compartment from penetrations in the firewall that are not tight.  This is especially true at speed.  Certainly check your firewall penetrations.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
StevenF
  • USA, NY, Merrick
« Reply #4 on: September 12, 2021, 03:37:35 »
I had a ton of heat coming into the car but so I replaced the firewall with a new pad and then installed a dynamat  style product
What a difference!
1971 280sl
Red Metallic
Bamboo MB Tex
StevenF
  • USA, NY, Merrick
1971 280sl
Red Metallic
Bamboo MB Tex
doitwright
  • USA, IL, Willowbrook
« Reply #6 on: September 17, 2021, 05:09:50 »
This may sound too obvious. Have you checked to be sure the heat is not coming from the heater core? The controls can be confusing for a new owner but the heating system does direct heat to the foot areas on the driver and  passenger side.
Frank Koronkiewicz
Willowbrook, Illinois
Mohan58
« Reply #7 on: September 18, 2021, 13:13:31 »
Thanks for the heads up. Will definitely look into this.
Cheer
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Norm
  • USA, TX, Wimberley
« Reply #8 on: September 18, 2021, 17:13:51 »
You should probably also check your heater core valve.  Mine would not close properly and continued to allow hot coolant through the core resulting in the same problem you described.
There are two ways to check this.  An easy check is to adjust the heat to maximum, feel the heat coming in by the floor, then reduce the temperature lever to minimum and see if the temperature of the air coming in is reduced.  Another way is to block the input (I inserted a steel ball bearing in the inlet hose) or bypass the heat exchanger by connecting a section of hose from the input hose to the output hose in front of the firewall and then see if the heat entering the cabin stops.
If the heater core valve is the problem there is info in the Technical manual to check if it is installed correctly and / or replace it.  Replacement valves with the appropriate washers are readily available through several 113 part suppliers.
Good luck.
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
Mohan58
« Reply #9 on: September 18, 2021, 23:20:09 »
Thanks Norm.
Cheers
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
