Author Topic: any to tip to descaling the cooling system ?  (Read 2582 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: August 04, 2021, 12:20:07 »
This morning I gave my radiator to make it revised even if it looks good and has no leaks.
A little plate mentions 97 04, meaning from the pro I met this morning, that it has been refurbished in 1997 the 4th month. Since then impossible to know how many kilometers the car did, but I know it wasn't much (<50,000km for sure)
Apparently from the gauge and the short trip I did to the MOT the engine wasn't heating up.
I previously changed the thermostat to figure out that the aluminum housing under the durit was partially eaten by corosion... Additionnaly all the area was totally stuck with scale (see pics).
Cleaning everything wasn't a big deal, I found a topic here, and used clear water with my garden hose to flow it inside the block and the whole coolant system. Refilled it with fresh coolant, topped it, and went to the MOT without any issues.
Now this morning as I shook the radiator I understood there was some more little scale blocks inside. Some fragment fell down on the ground. It's white, sometimes blue / green and friable...
The pro will manage to clean and revise everything, but told me that probably the head and the engine block itself shall still be full of these scale blocks...
Any experiences / tips to help me cleaning this ? I can try to clean again with my garden hose but was wondering adding something to the water to make it more efficient, or aditionnaly some pressure or hot water...
Thanks in advance guys !
« Last Edit: August 04, 2021, 12:28:56 by Figoulu »
1965 230 SL
1991 Porsche 911/964 carrera 2
1990 Porsche 911/964 carrera 4 SOLD
2020 Harley Davidson Fatboy
2018 Harley Davidson Street Bob SOLD
2003 Harley Davidson Road King Classic SOLD
2017 Harley Davidson softail Slim SOLD
2008 Harley Davidson Softail Fatboy SOLD
My youtube channel #lfgdf
WRe
Re: any to tip to descaling the cooling system ?
« Reply #1 on: August 04, 2021, 12:43:44 »
Figoulu
« Reply #2 on: August 04, 2021, 12:45:21 »
Then l’ll try to clean up the cooling system with citric acid 👍👍
« Last Edit: August 04, 2021, 13:17:50 by Figoulu »
1965 230 SL
David Robinson
  • Ireland, Connaught, Galway
« Reply #3 on: August 04, 2021, 13:25:01 »
I did the back flush, got the radiator and heater matrix reconditioned. (new core) No more overheating.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #4 on: August 04, 2021, 14:16:24 »
Here is a back flush procedure that a sl113 member put together.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Figoulu
« Reply #5 on: August 04, 2021, 17:05:16 »
Thanks to all of you
When discovered the poor state of the cooling system I back flushed the system using the method from this forum 👍👍😡
1965 230 SL
