Author Topic: geblasegehause  (Read 2275 times)
jos93
  • Belgium, Flanders, houthalen 3530
geblasegehause
« on: August 08, 2021, 09:13:39 »
good morning
Between the geblasegehause and the two shells L and R is there a mousse, rubber, or nothing at all?
Re: geblasegehause
« Reply #1 on: August 08, 2021, 09:25:37 »
The SLS pictures are usually helpful to figure out what is where: https://www.sls-hh-shop.de/main/de/mercedes-230-280sl-w113/83-heizung
jos93
Re: geblasegehause
« Reply #2 on: August 08, 2021, 14:26:08 »
hey pawel66
i do not see it at sls in the red area ?
Re: geblasegehause
« Reply #3 on: August 08, 2021, 17:08:34 »
I had a bit of an issue locating the two parts you are showing, that is why I referred you to the picture. I guess this part - blower housing and the two side elements - are just one replacement part in the parts list (and shown like that on SLS picture), A 113 830 00 08 BLOWER. The picture in the EPC is similar to the one on SLS pages.
Therefore even if there were seals, you will not have them shown and specified.
Someone who dismantled the original part would have to tell. But also by logic, if this is the duct for the blown air, I would have cut a gasket out of a piece of thin foam and place there. You have this kind of gaskets in other places (parts 35 and 63 on SLS picture).
dirkbalter
  • USA, CA, Corona
Re: geblasegehause
« Reply #4 on: August 08, 2021, 20:01:15 »
Not sure what was done originally but I added a strip of foam gasket to the housing to seal it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
jos93
Re: geblasegehause
« Reply #5 on: August 09, 2021, 10:27:54 »
Thanks a lot  Pawel66 and dirkbalter
