Author Topic: Head gasket references  (Read 2752 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: August 09, 2021, 12:14:10 »
Hi gents
Just questioning myself about what i found after several web researches...
Head gasket...
I could only find one reference that matches the compression ratio of 9.5... well my concern is about what if:
- the engine has been rebored ?
- the head has been machined ?
- the block it self has been machined?
Normally we shall find references corresponding to at least thickness of the gasket, and diameter of the cylinders supposedly if they are from original size of rebored
Thanks 👍
1965 230 SL
1991 Porsche 911/964 carrera 2
1990 Porsche 911/964 carrera 4 SOLD
2020 Harley Davidson Fatboy
2018 Harley Davidson Street Bob SOLD
2003 Harley Davidson Road King Classic SOLD
2017 Harley Davidson softail Slim SOLD
2008 Harley Davidson Softail Fatboy SOLD
My youtube channel #lfgdf
Re: Head gasket references
« Reply #1 on: August 09, 2021, 12:35:16 »
A standard head gasket is used in all these cases.
Figoulu
« Reply #2 on: August 09, 2021, 16:50:44 »
No way that valves meets the pistons ? 🙈🙈🙈🙈
1965 230 SL
« Reply #3 on: August 09, 2021, 18:29:24 »
No problem unless something gets cut below factory specs.
Figoulu
« Reply #4 on: August 09, 2021, 19:20:25 »
Still surprised... but other times means other performances and other practices
1965 230 SL
MikeSimon
  • USA, OH, North Royalton
« Reply #5 on: August 10, 2021, 11:26:03 »
If you have a possibility to make yourself familiar with the valve timing in detail, you will see that no valve is extended to full opening at piston tdc.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
