Author Topic: Window glass rattles because jaws fell off.  (Read 1985 times)
Jack Hernan
« on: August 19, 2021, 23:08:52 »
How do I reattached window jaws that have fallen off( epoxy, super glue, silicon caulk?). Is there a special felt type material that goes into the channel before fastening the jaws to the glass? What is s good cleaner for the track the jaws slide in. Any recommendations for track lubricant after I clean it?
Re: Window glass rattles because jaws fell off.
« Reply #1 on: August 20, 2021, 00:39:32 »
Welcome to the Group The search is your friend here, using the search button in the home line.
There are quite a few comments on the subject both on the Forum and how to in the Technical Manual where Full Membership is needed.
Here is a start.
https://www.sl113.org/forums/index.php?topic=31608.msg229260#msg229260
Membership Administrator
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #2 on: August 20, 2021, 05:51:21 »
Hello Jack,
You can do the job without removing the glass from the door. Clean the metal window guide channel in the door. Clean both sides of the glass where the jaws will be installed. Also clean the inside of the jaws with alcohol. Plain rubbing alcohol works well. Use clear silicone adhesive/sealant. The silicone is thick enough and the felt is not needed. I like to use silicone because it is thick enough not to drain off like epoxies. It is also an excellent adhesive to use on glass. Roll the window half way up.  Fill the glass slot in the jaw with silicone. Install the jaw on the metal window channel (below the glass) and carefully slide it upward into position on the glass. The excess silicone can be removed with paper towel or rag. Repeat the process on the other side. The window should not be moved for 24 hours. After the silicone has set to full strength (24 hrs.), you can use some light oil in the window channels to lubricate the sliding jaws. Be careful not to install the jaws too far up on the glass or it will prevent the window from rolling all the way up.
col320ce
« Reply #3 on: August 23, 2021, 14:04:01 »
Polyurethane adhesive also works well
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
