Author Topic: Bulb Question  (Read 3132 times)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
Bulb Question
« on: August 28, 2021, 23:06:52 »
On a 230Sl, there are multiple bulbs in the taillight assembly.  There two small bulbs (Tail  4W / Base: BA9s) similar to a flashlight bulb, which are stacked behind each other.  My question:while I understand that they are the "tail light", should both go on or should it only be the rear bulb?  If so, what is the forward bulb in the assembly for.. I can get the rear bulb to go on but not the forward bulb.  I am sure this is a naive question, but I am stumped.  Forgive my naivety
JB
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
Re: Bulb Question
« Reply #1 on: August 29, 2021, 01:42:44 »
One is the tail light and the other is the parking/clearance light: https://www.sl113.org/wiki/Electrical/TailLights
The latter should come on when you turn the headlight switch one stop left (or counterclockwise): https://www.sl113.org/wiki/Electrical/Lightswitch#Headlight
  • USA, NY, SOUTHOLD
Re: Bulb Question
« Reply #2 on: August 29, 2021, 20:26:36 »
thank you.  Ive owned my car for a long time, and always thought the parking light was only on one side, assuming it was only the "roadside' when parked.  Never  noticed the "headlight"  worked on both sides
jb
