Author Topic: Soft top cover  (Read 1856 times)
col320ce
Soft top cover
« on: September 01, 2021, 02:17:46 »
Can anyone show me how the front edge of the soft top is finished off? Does the leather wrap around or just finished flush with the edge?
Thanks everyone
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
kampala
  • USA, CA, Beach Cities
Re: Soft top cover
« Reply #1 on: September 01, 2021, 02:54:28 »
Col,
I took these photos when I dismantled my soft top cover -- have not installed new leather.   Hope these tell the story.
250sl - later - manual
280sl - 1971 - Auto - LSD
col320ce
Re: Soft top cover
« Reply #2 on: September 01, 2021, 21:17:11 »
Thanks Oz that's perfect.  It also shows proof that there is foam below.  I used 5mm but it would have been better I think if it was 2-3mm foam.
Col
1964 230SL
1965 250SE coupe
Re: Soft top cover
« Reply #3 on: September 06, 2021, 19:04:20 »
When I did mine I used this: MAGZO Foam Rubber Sheet Rolls, 1/16 Inch Thickness x 12 Inch Width x 4.9 Feet Length Closed Cell Neoprene Rubber with Adhesive Soundproof Padding,Soft/Medium Hardness - Freely Customizable https://www.amazon.com/dp/B07CJFQ6F9/ref=cm_sw_r_cp_api_glt_fabc_0Z32T1GKH1RQN3G4D0SW?_encoding=UTF8&psc=1
It isn’t an easy piece to do. I remember a fair bit of cursing.  I do remember the MB-tex (in my case) wrapping under at the ends.
« Last Edit: September 07, 2021, 09:52:37 by Peter van Es »
