I have a 1970 280SL that when the Gear Shift was in Park, the gear would not engage properly and the car would roll. In trying to fix that, from under the car we removed separated the lower linkage where the bushing from the upper rod. When then put the car in park and loosened the 2 bolts further up the rod and tried to visually align it so when put back together the transmission would be aligned with the gear shift lever being in the park position. Needless to say this was unsuccessful and now several of the gears are not lining up. For example, the 4th gear engages close to where the 3rd gear should be. Neutral is aligned in where the 4th gear should be and so on.
Is there a trick or other adjustments that should be made to make the transmission line up with the position of the gear shift? We worked for hours yesterday trying to align it from underneath to no avail. any help would be appreciated.
Thank you,
