Author Topic: Vent leaver replacement  (Read 2426 times)
Brennie
« on: September 08, 2021, 14:58:03 »
Hi
I wonder if replacing a vent lever( as seen in picture) is a massive job requiring the removal of the chrome vents.. I have one side ( left) missing on a RHD SL230
Thank you
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
Re: Vent leaver replacement
« Reply #1 on: September 08, 2021, 23:05:14 »
Brennie,
If you're talking about the black slider lever, my memory is that it just pops in or out; however, to put it in, you have to find the orientation of the sleeve it goes into (I usually just poke around a bit till I feel it go into the sleeve).
A related question for the group: if it were necessary to remove the chrome vent, how is that done with minimal breakage to the metal tabs (?) that hold it in place?
             -David
-David Pease
« Reply #2 on: September 09, 2021, 10:28:01 »
For the black tip - I do not think, indeed, you have to remove anything.
For the chrome, from what I remember, I started from the black box removal behind it. Then you can work on the clips. Plenty of posts on that on the Forum.
cfm65@me.com
  • Cape Town, South Africa
« Reply #3 on: September 09, 2021, 18:31:47 »
The black lever pulls out as said before. The vent cover has two pins to hold it in position. A tiny spring steel ring is pushed onto the pins to hold the vent grill in position.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #4 on: September 09, 2021, 18:49:34 »
In addition to the two pins there is also a hook at the bottom which is the real problem if it isn't already broken off.
The plate must be lifted up to release the hook and not pulled forward.
All described here with photos:
https://www.sl113.org/forums/index.php?topic=31304
Brennie
« Reply #5 on: September 10, 2021, 17:21:39 »
Thank you all for your help…lever ordered…perhaps one of the easier jobs it seems…maybe speaking too soon
