Author Topic: 1969 280sl thermometer location  (Read 3305 times)
edwardburak@erols.com
  • USA, VA, Marshall
« on: September 09, 2021, 12:30:05 »
1969 280sl USA version Automatic
I am getting ready to start my engine for the first time. I want the center instrument cluster installed for obvious reasons. I have already connected the oil pressure line to the engine and routed it into the dash. I know where the large electronic connector goes.
Where on the engine does the thermometer line bolt into? I have looked at my motor but cannot find it. the line seems long enough to reach to either side. I am aware of how fragile the line is. I will also bench test it with a heat gun before I install it.
If you could either tell me where or show me a picture, it would be greatly appreciated. Or any other tips to go along with it.
thanks for your help
Re: 1969 280sl thermometer location
« Reply #1 on: September 09, 2021, 13:44:45 »
On my engine (late 280Sl euro) it is as per the arrow.
Leester
  • USA, VA, Lorton
« Reply #2 on: September 09, 2021, 13:56:12 »
And if you have the early version M130 engine with the "pod" the temperature sensor goes in the pod.
Lee Backus
1963 220SE Cabriolet
  • USA, VA, Marshall
« Reply #3 on: September 09, 2021, 16:29:11 »
I am unfamiliar with what 'pod' you are referring to. what is its purpose? Where on the motor is it?
« Reply #4 on: September 09, 2021, 17:04:17 »
This is where the thick coolant hose going to Injection Pump begins. The hose is reddish on the picture.
  • USA, VA, Marshall
« Reply #5 on: September 09, 2021, 17:07:31 »
Ok, I will check that when I get home tonight
« Reply #6 on: September 09, 2021, 18:26:08 »
I marked the pod and the sensor on the picture.
  • USA, VA, Marshall
« Reply #7 on: September 10, 2021, 11:33:29 »
I found the location on my motor. Thanks for your help
