Author Topic: Putting bulk pictures into the Originality area of the Technical Manual  (Read 13271 times)
Dear all:
One of our members indicated that he had a set of photos from an extremely low milage original car and seeking info on where he could put them for others to use if needed. With limitations on numbers and size of photos that can be posted, he was seeking a solution.
The originality section in the Technical Manual (https://www.sl113.org/wiki/Originality/Start) was developed to enable good photos of very original cars to be put there to be used by Members as reference material. The way this works is that you send your collection of high resolution photographs to admin@sl113.org using a transfer service like https://wetransfer.com or put them somewhere where Peter can download them in original size. He will then add them to the Originality Section of the wiki where all Full Members can access them.
« Last Edit: September 12, 2021, 11:52:11 by Peter van Es »
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
Re: Putting bulk pictures into the Originality area of the Technical Manual
« Reply #1 on: September 11, 2021, 05:41:06 »
Garry,
Was the email ID meant to be "admin@sl113.org" rather than "amin"?
           -David
-David Pease
« Reply #2 on: September 11, 2021, 08:13:55 »
Correct, tks David, admin@sl113.org should be used.  Have amended post. 😉
