Author Topic: Accelerator Pedal Plastic Slides  (Read 1653 times)
Leester
  • USA, VA, Lorton
« on: September 13, 2021, 18:13:17 »
Tried searching - maybe missed it but Authentic Classics sells a piece plastic slide set for the accelerator pedal. When I looked at my old one, I only had one of the two plastic pieces. I assume these enable the pedal to slide more easily on the shaft but I can't quite figure out how they should be installed on the back of the pedal.  Anyone know?  Thanks in advance.
Lee
Auth Classics part:   https://www.authenticclassics.com/Mercedes-Slide-Plate-set-for-Gas-Pedal-p/auth-009655.htm
Lee Backus
1963 220SE Cabriolet
1985 500SEC
dirkbalter
  • USA, CA, Corona
Re: Accelerator Pedal Plastic Slides
« Reply #1 on: September 14, 2021, 00:18:43 »
The slotted one against the bottom solid one top.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Leester
  • USA, VA, Lorton
« Reply #2 on: September 14, 2021, 14:25:31 »
Many thanks!!
Lee Backus
1985 500SEC
