Author Topic: High Beam Switch  (Read 3955 times)
zak
  • USA, NJ, Bernardsville NJ USA
High Beam Switch
« on: September 13, 2021, 21:24:59 »
My late model 1967 250 SL has the high beam switch on the floor as a foot pedal switch.
When did MB change to using the directional stalk on the steering wheel to operate the high beams ?
I looked in the 250 SL factory changes but couldn't find.
Maybe done for 280 SL ?
Just curious.
I also remember back in the 1990's an aftermarket supplier offered a replacement stalk and wiring - to wire the high beam control to the directional stalk as an " improvement".
I think it was $ 40 bucks.
thanks,
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
MikeSimon
  • USA, OH, North Royalton
Re: High Beam Switch
« Reply #1 on: September 13, 2021, 21:27:58 »
My 1971 280SL still has the foot operated high beam switch
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: September 13, 2021, 21:58:07 »
Somewhere in our "Pagoda cosmos" for lack of a better expression there are wiring instructions to add high-beam "flashing" capability to the stalk. Somewhere I have this wiring, and I was told it was "done" to my car but it never worked and never bothered to troubleshoot it.
I tend not to drive at night...so it didn't get any kind of priority.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #3 on: September 13, 2021, 22:39:21 »
My car is a 1969 (1970 Model) and it has the flashing on the stalk and the foot switch and I'm sure it came that way.   Maybe it was a European thing?
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
« Reply #4 on: September 14, 2021, 00:06:10 »
My '69 has both the foot switch as well as the 'flash to pass' on the stalk. It's a US model car.
« Reply #5 on: September 14, 2021, 05:36:28 »
I do not suppose the foot switch for high beam was ever changed during the W113 manufacturing. The steering wheel switch was for short high beam flash operation only. We said this function was not wired in some of the US cars.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #6 on: September 14, 2021, 13:46:44 »
I followed the instructions here to add high beam flashing to my car.
https://www.sl113.org/forums/index.php?topic=25611.0
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
SEB
  • Germany, Berlin, Berlin
« Reply #7 on: September 14, 2021, 18:22:14 »
Since long time I was waiting this discussion.
I'm not sure, but before the restoration I can remember that my early 250SL  German version had the flash lights in the steering wheel. Later, after the car got an aftermarket replacement, that does not have it. So I am a little confused.
Now I purchased again an original 230 SL/250SL switch - how can you check it dry if it has this function?
Many thanks for any help? As you know the process is complicated and takes some time, so if I can check it in front of it it will be great.
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
« Reply #8 on: September 15, 2021, 19:35:04 »
SEB, I think the switch is there, just may not be connected - pins would be missing.
Here is quite a lot of info, 280SL, but could be a good guide: https://www.sl113.org/wiki/Electrical/SteeringColumnSwitch
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #9 on: September 15, 2021, 20:44:52 »
I agree with Powell, the switch is already on the stalk. Pins are either missing or not connected on some US cars. I have another period US sourced VW battle with same issue.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
SEB
« Reply #10 on: September 16, 2021, 13:35:41 »
Thank you Pawel, I will go trough this instruction.
Sebastian
« Reply #11 on: September 16, 2021, 16:16:50 »
I did not have 250sl wiring diagram to check the colors and connections for you, I only have the 280sl that is in Tech Manual...
SEB
« Reply #12 on: September 16, 2021, 17:49:24 »
I have an early 250SL, so the solution is similar to the 230SL, the late version is the same like the 280SL, but we will with my mechanic check it. Today you made me realize ,that there really are many interesting and usefull things/ information on this site that I do not.
Thank you!
Sebastian
