Become a
Full Member
Emergency Contact List
Inlet manifold heat shield 230 SL
Topic: Inlet manifold heat shield 230 SL (Read 1453 times)
gordon
Full Member
Senior
United Kingdom, England, Burntwood
September 16, 2021, 12:36:11 »
From the attached picture do I need to bend the end portions down and the rear parts upwards. I guess it needs to be fed in after both manifolds are bolted up then the throttle link poked up from below.
Full Member
Platinum
USA, OH, Blacklick
Re: Inlet manifold heat shield 230 SL
September 19, 2021, 05:33:54 »
At the exhaust manifolds, the aluminum turns upward. At the intake manifolds the aluminum turns down.
