Author Topic: Engine cylinder sleeve  (Read 2034 times)
steves sl
  • USA, WI, CEDARBURG
« on: September 17, 2021, 20:56:33 »
1965 230sl.....engine 127 981 10 005407. I need a definitive answer. Is it possible to sleeve a cylinder on the described engine, it has been bored 30 previously. 1 cylinder is bad (rust), is a long story about how it happened, OK X wife's son in law, wet rags in-cylinder when the engine was in storage.
S. Schlaefer
Re: Engine cylinder sleeve
« Reply #1 on: September 19, 2021, 05:28:06 »
It can be sleeved.  The 230 had thicker cylinder walls than either the 250 or 280.  I have heard of a 280 being sleeved in all 6 holes but I shudder to think what the stability over time was.
I would consider having it honed close to the limit before I sleeved it.
« Reply #2 on: September 19, 2021, 18:33:06 »
There's no problem with sleeving these engines as long as you choose the right engineers to do it.
steves sl
« Reply #3 on: September 19, 2021, 18:59:31 »
Thanks for the info. I should have said that the described engine has pistons 127-030-86-17, they are the largest repair sizes available 83.0 mm.
S. Schlaefer
« Reply #4 on: September 20, 2021, 04:57:24 »
Should be fine to sleeve.
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #5 on: September 20, 2021, 19:37:55 »
I did sleeve successfully ( driven 3000 miles since) a 280:engine so it should be no problem to sleeve a 230 Block
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
« Reply #6 on: September 20, 2021, 20:52:51 »
Me too, 280SL, similar distance covered...
