Author Topic: tachometer cable location  (Read 2309 times)
edwardburak@erols.com
  • USA, VA, Marshall
« on: September 20, 2021, 19:00:47 »
1969 280sl automatic
I need a tachometer cable
is this a correct replacement?
https://www.ebay.com/itm/293373154338
I have heard that it connects to the back of the injection pump, but do not see where
Where does it connect?
any other tips?
thanks
cfm65@me.com
  • Cape Town, South Africa
Re: tachometer cable location
« Reply #1 on: September 20, 2021, 19:19:37 »
Hi Edward,
No the tacho drive is not driven by the injection pump. The cable goes through the fire wall in the vicinity of the injection pump, then over the pump to the front LH side of the engine, next to the nr 1 spark plug. Follow the black cable.
Regards
Chris Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
  • USA, VA, Marshall
« Reply #2 on: September 20, 2021, 19:55:47 »
thank you.
I see it now
« Reply #3 on: September 20, 2021, 20:06:44 »
I gave you PN in the other post: A 113 542 07 07.
Yes, 1300mm looks correct. Perhaps check out Authentic Classic or Bud's Benz - you will be buying more parts...
  • USA, VA, Marshall
« Reply #4 on: September 21, 2021, 00:42:56 »
Yeah, I started two threads for items I thought were far different from each other. I am all good now.
Should I delete one of the two for forum simplicity?
« Reply #5 on: September 21, 2021, 14:49:29 »
Be aware ( for current and all future post readers) that tacho and speedo cables are different for RHD and LHD.
