Author Topic: heater flap  (Read 3007 times)
230slhouston
heater flap
« on: September 25, 2021, 21:21:26 »
Anyone know where I can buy a heater flap at a good price. Saw this on EBAY for almost $400 dollars. Need the right side.
The cable flange is broken on mine.  :(
Thank you.
Re: heater flap
« Reply #1 on: September 25, 2021, 22:17:30 »
PN is A 113 830 02 42 if you need ot search.
They are sold in pairs here: https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/83-heater-system/1-pair-mix-air-flap-p-135385 for EUR 300
I see then in pairs at Bud's Benz for $425.
Here is better, EUR 230 for a pair: https://oldtimer-ersatzteile24.de/Right-Air-Flap-for-Mercedes-Pagoda-W113
I glued mine together...
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
Re: heater flap
« Reply #2 on: September 26, 2021, 19:33:19 »
I ordered a left-side one from Marcel Kappen (in the Netherlands) a few months ago for €115, and was very happy with the service.  Here is the right one for the same price (plus shipping).  Overall, I paid about €147 shipped to the US.
   https://mercedes-classic-parts.com/product/ontluchtingsklep-kachel-rechts-v-nr-1138300242/
            -David
-David Pease
Re: heater flap
« Reply #3 on: September 26, 2021, 19:46:19 »
Didn't someone here have a file for 3D printing this part?
230slhouston
Re: heater flap
« Reply #4 on: September 26, 2021, 23:10:43 »
Thank you all for the replies and links.
Still a lot of money....I am too cheap. Rather spend the money on other visible cosmetics. I made the tabs with metal plate. I used the left side as a template to get the angle. Will use small machine screws to attach this to the flap, drill a hole and get a pin to fit with circlip (hopefully Ace hardware). Some pictures attached. Once I complete this, I will post a picture.
« Last Edit: September 26, 2021, 23:18:50 by 230slhouston »
dirkbalter
  • USA, CA, Corona
Re: heater flap
« Reply #5 on: September 26, 2021, 23:31:42 »
I did. I modeled them and I have no problem sharing them. When I was looking for the flaps, the only ones I could find came from Mr. Fiat and he was asking $ 450 each. At $250 for a set, I probably wouldn't go thru the trouble. They will need a little work after, such as inserting the pins.....
Let me know.
« Last Edit: September 26, 2021, 23:39:09 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
230slhouston
Re: heater flap
« Reply #6 on: September 26, 2021, 23:52:11 »
Hi Dirk,
Are these the molds in the picture? You just made the tabs or the entire flap? I don't clearly understand what you modeled.
Thanks.
dirkbalter
  • USA, CA, Corona
Re: heater flap
« Reply #7 on: September 27, 2021, 19:49:41 »
The pic may be a bit confusing, that’s how the come out of the printer. They still have some support material attached.
Below is a better pic.
I modified the seal face a bit in order to use a simple seal instead of the custom u shaped seal.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
