Author Topic: Hand brake questions  (Read 2127 times)
Brennie
« on: September 29, 2021, 12:41:36 »
Having just refurbished my hand brake..I have two questions…
In the picture,I’m guessing that there should be something to stop the spring dropping all the wat through..some kind of collar…it’s not inside ,therefore I can only conclude it was lost at the chromers ..can it be replaced or a substitute used?
Secondly.. I found this rubber u shaped piece and retaining clip lying in the tunnel where the cable enters on the floor…is it meant to be attached to the bottom of the hand brake itself?
Easy to take things apart…not so easy to put them back again…
Brennie
Re: Hand brake questions
« Reply #1 on: September 30, 2021, 11:08:12 »
Anyone who can help ? It would be much appreciated..
Thank you
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #2 on: September 30, 2021, 11:19:55 »
The black part isnt a part of handbrake system.
See attached pics for details.
1964 230SL
BobH
« Reply #3 on: September 30, 2021, 12:23:50 »
Looks like you're missing item number 9 on link below
https://www.niemoeller.de/en/w113/w113/B042/426
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Brennie
« Reply #4 on: September 30, 2021, 13:23:36 »
Yes…that is exactly what I need…now to try and find one..maybe I could fashion one using a washer and bolt and some epoxy as a stop gap…
Thank you
BobH
« Reply #5 on: September 30, 2021, 15:30:16 »
I know Niemoeller have a minimum order value, so it might be worth you making one or speaking to the SL Shop
UK delivered RHD
Blue soft top
Blue leather
Brennie
« Reply #6 on: October 08, 2021, 13:58:56 »
Thank you all…made one…
