Author Topic: Leaking brake booster repair?  (Read 1432 times)
Mohan58
  • Malaysia, Selangor, Petaling Jaya
« on: September 30, 2021, 09:48:31 »
Hi guys,
My brake booster has a vacuum leak which is also causing the brake to jam. When you step on the brakes the rpm goes up.
Does anyone know if I can get the brake booster refurbished? Would appreciate your help.
I am based in Malaysia & no one here can do it.
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Re: Leaking brake booster repair?
« Reply #1 on: September 30, 2021, 11:03:19 »
If rpms go up slightly and for a brief moment - it is ok.
Mohan58
« Reply #2 on: September 30, 2021, 12:21:03 »
Hi Pawel,
Unfortunately that is not the case. It remains high as long as you press the brake pedal.
Right now my mechanic has tried everything including servicing all the brake callipers and brake pump but my brakes are still binding. They said I should get the brake booster fixed.
Cheers
Mohan
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
