Author Topic: Is there a diff in M127 engines for a manual or auto gearbox  (Read 1938 times)
BartSt
  • Belgium, Flanders, Antwerp
Hi all,
Is there a difference in M127 engines for different type of gearboxes?
Curious,
Bart
BartSt
Re: Is there a diff in M127 engines for a manual or auto gearbox
« Reply #1 on: October 01, 2021, 16:48:15 »
Further explanation:
Some engines have engine numbers like
127.981.10
and others
127.981.12
One is automatic and the other manual
A friend mentioned it could be related to the flywheel/crank shaft balance in a manual which is not in an automatic.
Your thought are much appreciated
Bart
dirkbalter
  • USA, CA, Corona
« Reply #2 on: October 01, 2021, 19:09:27 »
You are correct, auto versus manual.
You can read up on that in our tech manual.
Different flywheels that need to be balanced together with the crank.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BartSt
« Reply #3 on: October 02, 2021, 05:46:04 »
Dirk,
Good morning.
I do not know where to look in the tech manual.
Can you point me in the right direction?
Bart
dirkbalter
  • USA, CA, Corona
« Reply #4 on: October 02, 2021, 16:59:06 »
Hi Bart,
I was talking about:
https://www.sl113.org/wiki/DataCard/VIN
0-manual
2-auto
Hope that helps.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BartSt
« Reply #5 on: October 02, 2021, 17:18:31 »
Thanks.
But where can I find the facts about the balancing of the flywheel?
Bart
dirkbalter
  • USA, CA, Corona
« Reply #6 on: October 02, 2021, 17:55:13 »
Oh,
My understanding is that only the M127 engines were balanced together with the fly-wheels. I am sure it was discussed here before. We also have some experts (JA17, Benz Dr....) that may weigh in here with more detail.
« Last Edit: October 02, 2021, 18:01:28 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #7 on: October 04, 2021, 06:08:14 »
The M127 engine is a "counter balanced engine". Each component is unbalanced, assembled and balanced as a assembly. Separate components must be kept with the original assembly or matched to parts they replace. In addition I think that the crankshaft on the automatic cars is completely different from the ones on the standard transmission cars.
« Reply #8 on: October 04, 2021, 06:09:57 »
The drive shafts for manual and automatics have different part numbers.
BartSt
« Reply #9 on: October 04, 2021, 12:50:29 »
Thanks all,
How bad is it to connect a manual engine to an automatic gearbox
and
An automatic engine to a manual gearbox?
Bart
