Author Topic: Does anyone recognize these spark plug wire ends.  (Read 2465 times)
« on: October 02, 2021, 14:16:23 »
I bought this used wire set on eBay.  I really needed the Beru Veso 1K ends on the distributor ends of the wires as they are the correct ends for the electronic ignition on the 70-71 US spec cars. The dark brown distributor cap was a bonus.
 The thing I am curious about is the spark plug ends.  They are not the normal slender Bakelite ends and I am wondering if maybe they are very early electronic ignition ends or ends from some other model?
MikeSimon
  • USA, OH, North Royalton
Re: Does anyone recognize these spark plug wire ends.
« Reply #1 on: October 02, 2021, 20:49:19 »
The spark plug ends on my car are neither this nor Bakelite. They are a thin metal.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: October 02, 2021, 22:26:14 »
The original 70-71 US spec cars have the metal ends.  I am not sure about the Euro version. I think the proper metal ends were Beru from introduction. I would guess they are tied to the Transistor ignition cars needing radio interference protection.
« Reply #3 on: October 02, 2021, 22:37:04 »
Perhaps in here you will find some answers: https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/15-electrical-equipment-at-engine/15-a-ignition
The connectors are relatively well described... No, but I looked again, they are different than yours.
« Last Edit: October 02, 2021, 22:42:17 by Pawel66 »
Jordan
  • Canada, ON, Jordan
« Reply #4 on: October 03, 2021, 12:21:41 »
I did a search in the tech manual about spark plug ends but didn't find anything.  Are these metal ends original for a 230SL (later)?
Marcus
66 230SL  Euro 4 speed
mbpaul
  • USA, NM, Albuquerque, NM
« Reply #5 on: October 03, 2021, 17:16:44 »
Jordon, my 1966 230SL has plug ends that look very similar to the pictures you show but they are Bosch, not Beru.
« Reply #6 on: October 03, 2021, 22:23:38 »
Pretty sure the Bosch wires were never installed from the factory but may be allowed for judging purposes as Mercedes may have supplied them as replacements at some point.
« Reply #7 on: October 03, 2021, 23:03:16 »
Well,  I think I just figured out the mystery. They are 5K Ohm ends so definitely Transistor ignition.   The Veso 1K ends at the distributor point me that way as well so they are either really early Transistor ends or the metal covered ends with the metal removed.  There are zero marks on them so I am going with they went with Transistorized ignition so they needed 5K Ohm ends then discovered an issue with noise suppression and added the metal shields.
« Last Edit: October 04, 2021, 01:27:07 by Shvegel »
mbpaul
« Reply #8 on: October 04, 2021, 01:22:49 »
I am sure Bosch was used in my 1966 230SL.  I have had the car since new and the wires themselves have been changed but the ends have not.  I do not know about other years--only the one that I have.
« Reply #9 on: October 04, 2021, 05:38:00 »
I have a huge box of misc. wires and ends Pat. Let me know if you need to look through the inventory. Maybe if the car was delivered with the optional radio, then the metal shields were provided?
MikeSimon
« Reply #10 on: October 04, 2021, 13:27:13 »
Beru used to be a really small, local supplier and Mercedes Benz (before the push to source globally and from EM countries) supported the local industry by sourcing OE equipment with them. As quite a few did not have the capacity to supply worldwide markets with spare parts, MB released other brands for that purpose, i.e.: spark plugs.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #11 on: October 04, 2021, 15:42:17 »
It is, as I understand, a reputable parts supplier these days. But I had quite negative surprise with these spark plug connectors - bought a set of them, then replaced with Bosch one by one as they kept failing.
And another experience with Beru part was the distributor cap for my W463 with M103 engine - it was just rubbish. My troubles ended when I bought Bosch cap from the dealer.
« Reply #12 on: October 04, 2021, 23:19:25 »
Thanks for the offer Joe.  I might take you up on it.
