Author Topic: Injection Pump Solenoids Bosch 0330101013 0330101012  (Read 2535 times)
Fonzi
« on: October 15, 2021, 17:20:41 »
I am trying to learn and understand the r20y injection pumps (from 1969 280se) I have here, and would like to understand what the top solenoid (Bosch 0330101012 ) and bottom solenoid ( Bosch 0330101013 ) are supposed to do.
The pump that was in the parts car with good compression seems to have a bad check valve on cyl 4 but I wonder if it has other issues as I note the solenoids have definitely been off and make even broken.  See the bottom solenoid in the background of the picture.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Injection Pump Solenoids Bosch 0330101013 0330101012
« Reply #1 on: October 15, 2021, 17:44:23 »
Top solenoid is for fuel enrichment in the FIP. I pushest the rack forward. It always engages when starting the car cold or hot.
The bottom is called the fuel cut off solenoid. It is engaged by a micro switches on the firewall and transmission when at idle and 3 or 4th gear I believe. In don’t remember exactly. It was designed to cut down on air pollution.
You can read about it more in the tech manual.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Fonzi
« Reply #2 on: October 15, 2021, 18:40:33 »
Thank you!  So I should get 12v to the top one when cranking.  Should 12v continue after I let off the starter?
I’m thinking I should leave the bottom disconnected when trying to get an old motor running.  Eh?
mrfatboy
    • Mrfatboy
« Reply #3 on: October 15, 2021, 18:44:16 »
Yes. You should get 12v on top solenoid only when cranking.
Some people disconnect none, one,  or both depending on their particular issue.
Signal Red
4 Speed
Fonzi
« Reply #4 on: October 15, 2021, 23:31:35 »
Thank you!
Just curious, after cranking, what handles the enrichment while the car is warming up?  Is there a wax bulb up top that somehow affects the amount of fuel that goes to the injectors?
mrfatboy
    • Mrfatboy
« Reply #5 on: October 16, 2021, 02:35:43 »
Correct. Do a search on “WRD” or Warm Running Device. Check out the tech manual. All the answers are there👍👍
Signal Red
4 Speed
