Author Topic: Cylinder head crack  (Read 3094 times)
Hollson
  • USA, FL, Naples
Cylinder head crack
« on: October 25, 2021, 18:50:15 »
I have a 66 230 sl that has a small crack in the head it’s leaking water out of the side below the spark plugs
Does anyone have a head or know of anyone who can weld the crack , if poss ?
Thx.
Re: Cylinder head crack
« Reply #1 on: October 25, 2021, 18:59:56 »
I have a good head but I'm in the UK so shipping will be expensive.
« Reply #2 on: October 25, 2021, 19:25:38 »
FWIW, my head (when my engine was rebuilt years ago) had a minor crack in it discovered during the rebuild process. It was repaired by Metric Motors. You may give them a call.
Alternatively, a bit closer to home, see if Noel's can help you. I thought they had gone out of business a while ago, but I was mistaken; I had spoken with Noel not all that long ago. It's worth a call.
Metric Motors https://mercedesengines.net
Noels http://www.noels.com/
Hollson
  • USA, FL, Naples
« Reply #3 on: October 25, 2021, 19:31:38 »
Thank you my friend.  Appreciate the help
 I will try noels first.
« Reply #4 on: October 25, 2021, 21:08:20 »
Any good welder should be able able to fix it, providing it can be fixed. Warming the head before welding is key.
Hollson
  • USA, FL, Naples
« Reply #5 on: October 26, 2021, 01:30:13 »
Thank you for the heads up.
 I will try to find a local welder
SEB
  • Germany, Berlin, Berlin
« Reply #6 on: October 26, 2021, 15:59:43 »
I have a good head but I'm in the UK.
I am looking for such head. Please contact me via PM or Whats App? +49 172 36 36 693
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
Hollson
  • USA, FL, Naples
« Reply #7 on: October 27, 2021, 11:42:28 »
I have been offered a head   The part no stamped in the head is 18001 626 01
Does anyone know if this would work ? Or what it’s off ?
Thx
BartSt
  • Belgium, Flanders, Antwerp
« Reply #8 on: October 27, 2021, 18:06:58 »
I have one spare for 230sl. Live in Belgium. PM for picts.
SEB
« Reply #9 on: October 27, 2021, 19:40:55 »
Sebastian
« Reply #10 on: October 28, 2021, 06:07:11 »
The M180 heads will not have a hole for injectors to be installed. On a M180 engine the injectors are positioned on
 the intake manifold.
« Last Edit: December 27, 2021, 00:00:45 by ja17 »
Hollson
  • USA, FL, Naples
« Reply #11 on: October 28, 2021, 09:17:02 »
Thank you.  Did not think it would work
Appreciate the help
