Author Topic: turn signal switch  (Read 1556 times)
zak
  • USA, NJ, Bernardsville
turn signal switch
« on: October 26, 2021, 21:41:07 »
My turn signal switch is sometimes falls out of position when I am making a right turn, but the left turn side works fine and stays put.
I recall reading an item in The Star mag tech section from 20+ years ago on how to fix the " droopy" signal stalk. I think it was written by George Murphy.
He said that the repeated use of the stalk rounded the edge that holds the stalk on place that activates the turn signal and recommended using a small file to somehow sharpen the edge to better hold the stalk in signal position.
Is anyone familiar with this procedure ? Right now I just hold the stalk in place with my left hand while turning right.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
doitwright
  • USA, IL, Willowbrook
Re: turn signal switch
« Reply #1 on: October 30, 2021, 13:26:54 »
Go to home page of this forum and search "turn signal repair" or "wiper switch repair".
I believe it is also covered in the technical manual.
Frank Koronkiewicz
Willowbrook, Illinois
