Author Topic: Carpet Gray Black ( Center Transmission ) cover - Manual  (Read 4015 times)
Benz280
  • USA, NJ, Jersey City
« on: November 05, 2021, 14:00:13 »
Looking for an original OE ( Used ) center carpet transmission cover ( Gray black ) as originally installed at the factory.
Prefer slightly used as to blend with the rest of the carpets.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: Carpet Gray Black ( Center Transmission ) cover - Manual
« Reply #1 on: November 05, 2021, 18:07:58 »
Do you mean the grommet or the actual carpet piece with the old grommet?
https://www.authenticclassics.com/RUBBER-GROMMET-CARPET-AT-SHIFTER-230SL-250SL-280SL-p/auth-005155.htm
Benz280
« Reply #2 on: November 05, 2021, 22:38:45 »
The actual carpet, apparently the previous owner spilled something on the center driveshaft tunnel.
All other carpet is in good original condition.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
  • USA
« Reply #3 on: December 02, 2021, 13:04:46 »
You actually mean the one that sits under the wood tray?  Or the front one with the shift lever opening?
There are two pieces.
Try a dry cleaner if they can remove the stain
Benz280
« Reply #4 on: December 02, 2021, 13:12:59 »
The carpet that surrounds the shift lever and goes down the side of the tunnel. Unable to clean .
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
