Author Topic: Steering wheel refurb  (Read 2670 times)
Hollson
  • USA, FL, Naples
« on: November 06, 2021, 01:04:53 »
Hi guys.
  I need my steering wheel refurbished. Does anyone know the best place to send it.  Or do any of you have a new Oem for sale
It’s off my 66 230 sl. It’s in black. Showing age and some cracking.
Thx
Alex D
  • USA, NC, Cary
Re: Steering wheel refurb
« Reply #1 on: November 06, 2021, 13:12:48 »
I used this place 7 years ago for my steering wheel and am happy with it.
https://www.steeringwheelbob.com
Alex D
1967 250 SL
Original 140K mi
181 Light Beige, with  112 Turquoise Interior
Hollson
  • USA, FL, Naples
« Reply #2 on: November 09, 2021, 03:18:18 »
Will check them out
Thx
zak
  • USA, NJ, Bernardsville
« Reply #3 on: November 10, 2021, 19:01:55 »
Alex, thanks for the tip. I spoke to Bob . He sounds like a pro and he is close by in NJ.
I plan to drop my steering wheel off to him after Xmas.
Now I need to find out how to removed the wheel with damage.
thanks again,
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
mBdrvr
  • USA, PA, Bethlehem
« Reply #4 on: November 10, 2021, 20:46:30 »
Steering Wheel Bob did a great job on mine!
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
PagodaFan
  • USA, FL, Tampa
« Reply #5 on: November 10, 2021, 22:51:03 »
I have an ivory refurbished steering wheel for sale if you are interested, for the 1963-1967 pagodas. Please email me if interested:
Fdiab62@hotmail.com
« Reply #6 on: November 11, 2021, 08:27:08 »
If I recall…
Pry the horn pad off (gently but it just clips in)
19mm socket, on an extender
Disconnect horn (think it’s on spade clips)
Mark the center position - Center or similar - before you pull the wheel. Thinking aloud, I wonder if some dotology could be used… dab of paint on splines on wheel and column after the nut is off but before removing the wheel…
Pull the wheel off
« Reply #7 on: November 11, 2021, 08:43:44 »
If the nut holding the steering wheel is too tight to just unscrew it, you may need a helper to hold the wheel while you are using force on the socket. I have never had a nerve to use the steering lock as a lock for unscrewing this nut - you can probably do it, but I just preferred to have a helper as well.
I would replace the spring washer. Can be bought at MB or probably most of the hardware stores.
dirkbalter
  • USA, CA, Corona
« Reply #8 on: November 11, 2021, 15:56:01 »
An impact wrench works well for loosening the nut. You don’t have to yank on the wheel.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #9 on: November 11, 2021, 19:27:18 »
x2 on the impact wrench. Amazing what a good one can do to undo a nut that can seem impossible to undo with the 'normal' approach, especially when you can't immobilize a nut effectively.
zak
« Reply #10 on: November 11, 2021, 19:44:42 »
Thank you, gents for the advise. The paint dabs are a good idea. I think I can yank it off.
I am a good yanker!
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
« Reply #11 on: November 11, 2021, 21:23:32 »
I did not have one at that time... I have one now, but I do not need to unscrew the steering wheel... Life.
David Robinson
  • Ireland, Connaught, Galway
« Reply #12 on: November 12, 2021, 10:27:28 »
Before and after of mine
dirkbalter
  • USA, CA, Corona
« Reply #13 on: November 12, 2021, 15:29:10 »
Did you do it yourself?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
David Robinson
« Reply #14 on: November 12, 2021, 15:49:04 »
Yes
dirkbalter
  • USA, CA, Corona
« Reply #15 on: November 12, 2021, 16:17:11 »
Looks great. I am planning to do it myself as well. Mine is not quite as bad as yours but has some cracks as well. Would you share your process?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
David Robinson
« Reply #16 on: November 12, 2021, 20:22:14 »
Yes of course, though note I am an amateur.
dirkbalter
  • USA, CA, Corona
« Reply #17 on: November 12, 2021, 21:52:16 »
Most of us are.  😎
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
