Author Topic: 5 Speed trans  (Read 1602 times)
gcdpetaluma
5 Speed trans
« on: November 16, 2021, 00:32:32 »
I have a ZF 5 Speed from 1966. I don't have a tach and would like to know the approximate "safe" shifting speed(MPH) for 1st, & 2rd gear.
Thank you for your help.
« Last Edit: November 16, 2021, 03:47:22 by gcdpetaluma »
Re: 5 Speed trans
« Reply #1 on: November 16, 2021, 16:08:41 »
Don't remember this clearly anymore when I drove the ZF 5-speed the last time...
Nothing peculiar.
Between 25 and 40 kms/h I would tend to say.
Depends mainly on engine speed. You do shifting with the ZF based on engine speed/or noise in the same way as you do with every other car.
Atazman
  • USA, Ca, Pleasanton
Re: 5 Speed trans
« Reply #2 on: November 16, 2021, 17:57:16 »
This might help.  I assume when you are talking "safe" you are talking about limiting your engine rpm.
If so, assuming you have a 4.08:1 differential ratio and stock tire size,  @ 6,000 rpm you would be going 27 mph in 1st gear and 47 mph in 2nd gear.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
DaveB
Re: 5 Speed trans
« Reply #3 on: November 18, 2021, 00:02:07 »
Will Samples has uploaded many useful videos here:
https://www.youtube.com/user/wfs52/videos
Including driving his new 5-speed 230SL:
https://www.youtube.com/watch?v=kIyvrI0bBeU
Is that an original color?
DaveB
'65 US 230sl 4-speed, DB190
