Author Topic: How Do I Get the A/C Evaporator Out  (Read 2033 times)
Scope9
« on: November 20, 2021, 04:59:19 »
I’m in the process of re-doing the A/C system on my ‘68 and have searched everywhere for info on how to remove the evaporator/blower assembly from inside the car.  It is a Kuhlmeister unit.  Despite removing just about every bolt and screw I could find, the thing remains solidly in place.
I’d be grateful if someone could advise me on where the fasteners are and how to remove the unit.
Re: How Do I Get the A/C Evaporator Out
« Reply #1 on: November 20, 2021, 10:10:32 »
I have a frigiking, on the underside are four holes via which you can reach the screws. Maybe the same with yours.
BobH
« Reply #2 on: November 20, 2021, 11:04:39 »
There are many old posts on this subject if you search, use the search button top left of the page
this post was regarding a 230SL, but may be the same for yours
https://www.sl113.org/forums/index.php?topic=21485.0
Perhaps you can contact the members who posted this and see if they figured it out?
« Last Edit: November 20, 2021, 11:21:05 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
johnk
  • USA, OH, Avon
« Reply #3 on: November 20, 2021, 13:46:54 »
I just installed one and the only screws I could find that needed to be used where the ones above, the right kick panel and the blower mount in back.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Scope9
« Reply #4 on: November 21, 2021, 19:48:25 »
Thanks for the kind advice folks—much appreciated.  The complication I discovered was that the last two screws securing the unit are rather diabolically hidden, requiring that the small “knee vents” at the bottom of the unit be removed to get at them.  The other two are accessed through the plastic capped openings nearby.
Just to make things a bit more interesting, one screw head had been snapped off and the other three all were different sizes with different heads.  The dealer-installers probably shouldn’t have been working for Mercedes.
The unit is out and I appreciate the guidance.
