Author Topic: Becker Grand Prix  (Read 9627 times)
  • USA, VA, Alexandria
Becker Grand Prix
« on: May 14, 2005, 20:44:16 »
Searched the archives and did not find a post on point.  I want to go from 2 to 4 speakers.  Will the Grand Prix Handle 4 speakers with good sound?
Anyone ever try an under the seat speaker?  I found one that is 3 inches high, 11 inches long and 8 inches wide.  Anyone know the under seat clearance?
Thanks in advance for any thoughts.
Mike Heagney
Re: Becker Grand Prix
« Reply #1 on: May 15, 2005, 06:01:27 »
Hi Tom,
I've just bought an 89 model Becker Grand Prix.
What speakers do you run with your unit. Are they footwell mounted.
The chassis opening holes for my old speakers are 100mm dia. each.
I'm only looking to use 2 speakers.
Mike.
64 230 SL....in boxes.
« Reply #2 on: May 15, 2005, 06:26:21 »
Mike,
Tom is talking about the original Grand Prix from late 60s/early 70s.
« Reply #3 on: May 15, 2005, 06:50:04 »
Correct-the earlier version of the Grand Prix.  My data card inidcates I had a Grand Prix from the factory, which is why I went with this model over the Europa that was installed by a prior owner.
« Reply #4 on: May 15, 2005, 08:14:47 »
What other cars shared this unit?  If any of the big body cars had this you'ld think they'd have multiple speakers.
How about the MB600 Pullman?
norton
« Reply #5 on: May 15, 2005, 10:23:21 »
Infinity has come out with a new line of speakers with high sensitivity ratings and they are 2 ohm, the Becker might be able to push 4 of these. http://www.crutchfield.com/S-D7c6da1UarL/cgi-bin/ProdView.asp?g=51800&I=108527I
Mike Halleck
Chesterfield Mi
71 280SL
68 250SL (parts car)
94 E320 Coupe
« Last Edit: May 15, 2005, 18:25:04 by norton »
« Reply #6 on: May 15, 2005, 12:16:41 »
I have 5 speekers in my 280SL 2 in the kick panels 1 in the top of the dash and two in the back soft top panel that is carpeted. I have a fader controll and my radio works fine. Know if I can get the becker cassette unite and the short wave to work I will have all that I" need to be comfortable to cruise.
« Reply #7 on: May 15, 2005, 13:48:31 »
Bob:
With the assumption that your head unit is stereo, is the center dash speaker wired left, right or exactly how did you deal with that issue?
1964 356C
1973 911S
2002 SC430
2004 A4 3.0
« Reply #8 on: May 15, 2005, 17:06:22 »
Tom, you may want to give Bjorn at Sports Leicht a call.  I believe they've addressed these issues in the past.
With your addition of the kinder seat you may not be able to place speakers over the rear parcel shelf as Bob has done.
Performance Products has a 4 speaker system for the 107.  The system features "2 midrange/tweeter speakers w/ 2 8"woofers for the rear". The rear parcel shelf has rectangular cutouts on the vertical section.  By utilizing Ed Cave's method of acoustic material to match the interior it would be less noticeable.  The second set could be placed in the kick panels.  The only catalog I have on hand is the Spring/Summer 2004, page 30 Ref# 6138.  The performanceproducts.com site did not show a picture of this item.
« Reply #9 on: May 15, 2005, 20:55:50 »
Hello Tom,
The Same radio powered four speakers in the Mercedes sedans of the era. You may wish to get a original balance control for the four speaker set-up also. These were mounted on the dash or consol of the sedans. It may mount nicely next to the rear hardtop defroster button on a W113center consol? I doubt that you would want to drill a hole and mount it on the dash.
Lindsay
« Reply #10 on: May 23, 2006, 21:01:24 »
Does anyone have a photo of the original Stereo Becker Grand Prix that would have been fitted to a US Version '70 or '71 280SL? If so, could they post it.  I'm assuming that the Grand Prix's of that era had the separate amp that was connected by a Multi-pin DIN cable? I've seen Grand Prix's with a large scale multi-band display as well as ones that have a small scale the same size as a Europa Stereo scale. Also, what are the buttons labeled? Are they LMKUU or BC & FM for the US market? Finally, does anyone know what the serial number prefix letter should be D, E, F, G, etc for a 1970 production model? I believe the letter correlates to the year of manufacture of the Becker. I'm trying to source out what would be absolutely correct for my car. (Produced 11/70) Yes, I'm a bit of an authenticity nut. Thanks.
Lindsay (Southern California)
180G, 396 G  Top
M-B Tex  Blue
« Reply #11 on: May 24, 2006, 06:10:55 »
Lindsay,
"LMKU" is for a European car.
