Hi everyone, i have no light at the dash heaterlevers . The light is ok on the clock and rev counters , central cluster . So i tgnink that the issue comes from the wiring or the two led bulbs recently replaced....
I had a problem already with the led of the red charge ignition , even with the 88 ohms resistance that i fitted as per the technical manual .
I think it's a problem with the led bulbs but i have to verify ...
the car is actualy far from home and i can't have an acces ! my question is :can i have acces to the bulbs without dismantling the heater levers....may be can i replace the bulbs after taking out the dash speaker ?
I remember the hard job i had when i refurbished all the levers and flaps....and be happy to remake that!
I should have the answer to that question...may be .alzheimer knock at tha door ?
Photos below when i was removing the levers two years ago.....
May be it is "only" the first plug on the left lever disconnected by the mechanic working in the dash after me ?
