All,
Bart from Belgium again.
After removing the dash instruments "85" times (to redo LED, connect speedo cable to tach and vice versa...
and a lot of other small stuff) I thought I was finished and put all back together.
But then Murphy came by.
Now I have problems with my key. Sometimes it will move to position 1, sometimes it doesn't. And I even can turn it to -1.
So I'm digging into older posts, but I read some conflicting info.
Maybe you can help
1. After removing the Chrome inner bezel, I'm supposed to see a "C" clip which will hold the key tumbler
2. But another post talks about " ... loosen the 10mm bolt and clamp ... install the key again and move to position 1 and depress the hidden pin ... to take out the ignition lock assembly
I do not know which version is correct for my 230sl
And furthermore I read that the lock tumbler from a 111 coupe or 108 sedan will work as a replacement for my 230 tumbler.
But can I fix my 230 tumbler or is that impossible?
Hope somebody can share a bit of his brainpower.
Be well,
Bart
