Author Topic: 230 SL key Tumbler (ignition)  (Read 6165 times)
Re: 230 SL key Tumbler (ignition)
« Reply #25 on: December 16, 2021, 18:26:51 »
I did not find any instruction in the first BBB (early), just checked.
BartSt
  • Belgium, Flanders, Antwerp
« Reply #26 on: December 16, 2021, 18:52:11 »
Pawel,
What do you mean?
Will it (W108) fit?
Bart
« Reply #27 on: December 16, 2021, 20:24:11 »
No, sorry, I was to look for the way of disassembly of the early lock in early BBB.
BartSt
« Reply #28 on: December 17, 2021, 12:56:03 »
Ok all,
Mr Leo Peterssen was correct.
I drilled it out.
Now I'm waiting on the people from Haas Classics to tell me a W108 tumbler would fit.
They are the one selling one, but they had their doubts ...
Bart
« Reply #29 on: December 17, 2021, 13:50:43 »
I have those barrells in stock.
BartSt
« Reply #30 on: December 17, 2021, 18:26:49 »
Excellent.
The w108 or the w113?
Bart
BartSt
« Reply #31 on: April 25, 2022, 19:45:07 »
All,
Good evening.
Bart from Belgium back.
After a winter working on my other restoration project (Etype, series 2, 2+2) I'm now finishing my 230SL
As you might recall I had to replace the ignition barrel (with a new key).
The first one I bought (a new one) was stuck after 10 times and I had to send it back and the nice people of SLS gave me a 100% refund, only to hear the ran out of barrels.
So I went to Niemoeller. They were able to sell me a new one.
This barrel was on my desk the entire winter (smiling at me)
I just came back from my garage after installing it back into the car.
But then ...
When I turned the key I was able to go from 0 to 2. The red ignition light turned on, but then nothing.
It felt I was not able to "reach" the ignition engine. I could not turn the key "far enough" until the moment the engine turned.
But it felt like a normal turn ...
So with this brief intro, and my explanation on what I experienced ... Who can help me?
Be well,
Bart
lpeterssen
  • USA, FL, Miami
« Reply #32 on: April 25, 2022, 23:47:55 »
Hi Bart
Nice to hear from
You.  Refresh my mind…. Your car has originally a manual or automatic transmission?
If it is automatic…. There is a kind of kill switch on the firewall which verifies if the car is in neutral or parking position to allow passing the T50 signal
To the starter selenoid
Check that.
Also if it manual there is a positive signal going to the TTS at  top of the TOP of engine next to the FIP at the front that receives in one of its poles also T50 when cranking.
Maybe ignition switch is doing its thing but signal T50 is not passing through
Best Regards
Leo
BartSt
« Reply #33 on: April 26, 2022, 05:48:59 »
Leo,
Hi, nice to see you again!
If I take the barrel from the electrical component, which is held in place by 3 crews on the back, and then use a screw driver to turn, the car starts ...
If looks like it will not turn far enough ... but does not make sense ...
Bart
lpeterssen
  • USA, FL, Miami
« Reply #34 on: April 26, 2022, 11:15:58 »
Bart
If you did the screwdriver experiment without the barrel, then you are right the problem is related to the barrel position into the lock assembly.
If the barrel turns outside without restrictions, then look carefully something is in the path or not clean enough.
Best regards
Leo
BartSt
« Reply #35 on: April 26, 2022, 13:25:11 »
Leo,
Could it be that the inanition switch is "kaput"?
Bart
lpeterssen
  • USA, FL, Miami
« Reply #36 on: April 26, 2022, 19:23:46 »
Do not know my friend. Have you tried bringing the whole ignition assembly and tumbler to a locksmiths
BartSt
« Reply #37 on: April 27, 2022, 14:02:22 »
Not yet.
I bought a new ignition switch. Will try that path first ...
Will let you know
Bart
BartSt
« Reply #38 on: May 07, 2022, 05:36:20 »
It works!!!
(I'm a happy man again)
Good weekend
Bart
lpeterssen
  • USA, FL, Miami
« Reply #39 on: May 07, 2022, 10:51:33 »
Congratulations, happy weekend
