Author Topic: To paint the car or NOT ?  (Read 27957 times)
hbrand
  • Edgewater
« on: December 14, 2021, 20:48:22 »
Update: Hood and trunck is painted now. Pictures on Google. Can you tell ?????
I bought a one owner 69 280SL and worked a few month resulting in a great driving car.
I like it the way it looks, never painted or welded. 40 years inside storage in Texas. But wife want's the car painted.
So, what are you thinking ?
Pictures are on Google:
https://photos.app.goo.gl/EK42LeuXyodquBdJ8
Greetings, Harold
« Last Edit: December 11, 2024, 19:27:25 by hbrand »
hbrand
  • Edgewater
Re: To paint the car or NOT ?
« Reply #1 on: December 14, 2021, 21:09:49 »
Work performed on 280SL
Recently:
New both motor mounts
New both sub frame mounts
New steering link and shock
Some new coolant hoses and clamps
Coolant flush, correct stickers applied
Starter serviced, freeze cover resealed
Brake and clutch fluid changed
Engine oil, filter
Transmission and rear axle oil changed
Distributor and iginition serviced
Hand cleaning 4 wheel wells to show originality
Pressure washing front and rear suspension
Handcleaning same, some painting and detailing
Visible original inspection marks touched up
Original nuts and bolts touched up
Replacment rear calipers cleaned and painted
Mechanical injection readjusted
Cold start and warm up circuit repaired
New German leather seat upholstery installed
Left trunk floor removed surface rust and painted
Removed old trunk seal
Treated surface rust in trunk seal channel
Installed new trunk lid seal
Installed soft top side gaskets to door windows
Repaired original matching numbers radio
Work done by first owner:
Radiator recored
4 brake calipers, all hoses, new brake booster and master cylinder
New Clutch master cylinder, hose and slave cylinder
New or refurbished gas tank
Fuel pump serviced
Fuel injection pump rebuild
6 new fuel injectors
Shifter linkage rebuild
New soft top installed
New trunk rubber mat
Heat insulation on floors
New cocomats
Speedo cable replaced
Heat insulation and carpet installed
All instrument bulbs changed
Clock repaired
Heater levers and flaps replaced
Ignitor ignition installed into distributor.
Coil for that
Many parts replaced over time.
Jordan
  • Canada, ON, Jordan
« Reply #2 on: December 14, 2021, 21:42:35 »
Greetings, Harold
Harold, hate to say it but you already have your answer.  What any of us here have to say is immaterial.
Marcus
66 230SL  Euro 4 speed
« Reply #3 on: December 14, 2021, 21:59:04 »
Driving around with the hood and trunk unpainted might be what's stopping her from enjoying a car ride! That would be a great pity.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #4 on: December 15, 2021, 00:12:45 »
I don't see the need to have a silver bonnet and boot on a red car.    Even an unpainted carbon fibre hood may look cool for the true tuner car nut but I think the average person (my wife and daughters included) thinks that look is "unappealing".
If you are very careful with your prep and application, a good quality custom matched paint in a spray bomb from an automotive paint store would probably do a good enough job to get your wife in a single colour car.   Approx 1/3 of my car is painted with a spray bomb in my garage and I have never had anyone point it out.  After painting I polished the paint with a fine surface refinisher (by hand) and then a nice wax and unless you are at exactly the right angle its really hard to tell.
I can tell, but I can also tell where my wife's new car was repainted at the dealer.  The salesman, sales manager and some other important looking guy were all adamant there was no repainting until the owner brought out the paint guy who instantly picked the same location of a repair as I did.    Unless you are a "paint guy" I wouldn't worry too much about the quality if you take your time unless you are going for a concours car.
Or you can always go to a body shop to get it done properly.   I just like doing things myself.
« Last Edit: January 12, 2022, 21:23:48 by Bonnyboy »
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
johnk
  • USA, OH, Avon
« Reply #5 on: December 15, 2021, 00:31:38 »
Your pics do not show close ups of the body paint so I am not sure what other defects you have besides the unpainted hood am trunk. However solid red is not difficult to match. I would have an experienced painter paint the hood and trunk to match and do what other corrections they can along with a good buff and I think you both will be very happy.
Are you sure it’s original paint though?  Not sure why the hoods would be stripped and the rest of the car in original paint.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
specracer
  • USA, MA, Duxbury
« Reply #6 on: December 15, 2021, 01:25:35 »
Sure looks like a clean car. I love originality, if indeed the majority of the body is original, I would leave it. As mentioned, getting the hood and trunk red would help a lot.
« Reply #7 on: December 15, 2021, 02:19:18 »
I would take it to Pierre Hedary to look it over.  Super honest guy!
http://www.pierrehedaryandco.com/
« Reply #8 on: December 15, 2021, 03:10:12 »
Paint hood and trunk lid, have the rest 'corrected' (likely compounded/polished) if at all possible and everyone should be happy.
Like Bonnyboy I like doing things myself and over thanksgiving painted my own car in the garage. $500 worth of primer, sealer and paint and it looks stunning. This is only the second car I ever painted.
« Last Edit: January 11, 2022, 02:06:02 by Cees Klumper »
cabrioletturbo
  • Canada, Ontario, Ottawa
« Reply #9 on: December 15, 2021, 05:42:35 »
Let's say all is original on the car otherwise. Did you consider just a vinyl wrap-up for the hood and trunk lid?
You may always consider a full repaint down the road. this would be a cheap and effective way to accomplish the looks without breaking the bank. Or putting a sub-par coat of paint now, which you may regret later.
Igor
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #10 on: December 15, 2021, 17:12:58 »
Any body shop worth its salt should be able to paint match, blend and leave as much original as possible.
However, if the fenders/doors' paint isn't that great, ya, just paint the whole thing.
I concur; looks pretty stupid as-is.
  • USA, WI, Mequon
« Reply #11 on: December 15, 2021, 20:20:19 »
If your thought is not to disturb originality in this car, to me, the issue is moot as this car has veered far from original already.  If new paint helps to enjoy the car, do it without guilt.
Painting the hood and trunk are a thought, but good luck matching red, especially old red.  Almost impossible.
hbrand
  • Edgewater
« Reply #12 on: December 20, 2021, 23:53:45 »
Thank you for the comments.
Will first try to paint hood and trunk. Then will see.
Or might want to sell to good home.
Greetings, Harold
hbrand
  • Edgewater
« Reply #13 on: December 25, 2021, 18:56:28 »
Your 250Sl must be worth more than 150K  or ??
Greetings, Harold
  • USA, WI, Mequon
« Reply #14 on: December 26, 2021, 14:08:49 »
Greetings, Harold
I'm not sure if you're referring to mine, but I couldn't say.  While early 250 SLs are the rarest of 113s, the market at this time does not put a premium on them.  A 280 in equal condition would sell for more, I think.  Doesn't matter though, I'm not selling.  Have had it 14 years and it's a car I can continue to comfortably drive as I age.
MikeSimon
  • USA, OH, North Royalton
« Reply #15 on: January 10, 2022, 20:11:16 »
Regarding a previous comment: Any shade of red is one of the hardest colors to match! Ask any professional painter.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #16 on: January 11, 2022, 01:17:20 »
If painting the hood means that the lady in charge will not be embarrassed to be seen riding around in it, then I would paint it.  The whole point of having one of these cars is to be able to make great family memories on the road.  Spectrographic paint analysis makes it possible for a good painter to match non-metallic paint pretty closely these days, certainly close enough to transform what is understood to be a good running car into an enjoyable driver for years to come.  Regardless of motivation, the car will be more valuable with a red hood than it is now with a bare aluminum hood.
georgem
« Reply #17 on: January 12, 2022, 20:56:55 »
Having been married nearly 45years I don`t understand why you have even asked the question - just get the boot and hood painted now  - you know you are going to agree with your wife- if you want your wife to enjoy riding in your toy and support your hobby - just do it.  The originality issue is a red herring - no Pagoda ever left the factory like that - or if it did it was a mistake and in my very humble opinion it just looks bizarre
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
cabrioletturbo
« Reply #18 on: January 12, 2022, 21:29:14 »
I vote for a wrap with a picture of her favorite bag on it.
Joking...
Igor
« Reply #19 on: January 13, 2022, 15:57:06 »
Harold, consider joining our group as a full member and assuming all the benefits that come with it.
I have a 568 Signal Red car.  Back in 2015, I had some repair to a fender that obviously required paint. My esteemed restoration shop, (Motorwerks Group, Commerce Michigan, owned by Dr. Satish Tumalla), told me (and you've seen that repeated here) that RED is one of the hardest colors to match; and yes they have all the sophisticated equipment IN HOUSE to do so, along with top notch craftsmen.
So, the fender repair begat painting the hood as well, the front clip, and careful blending down the sides of the car, with the goal of NOT being able to tell it was spot-painted. Those with a long memory may remember the paint was barely dry on my car at the last PUB in Blacklick.
Then, more recently (2020-2021), I had the door changed (from 230SL --> 280SL) and with that painting, the same kind of thing. Paint the door, and part of the fender and rear to blend it all together AND match the newly painted hard top as well.
The mark of a good job is not being able to tell there was a job in the first place.
hbrand
  • Edgewater
« Reply #20 on: January 22, 2022, 22:59:41 »
Will start to get some enamel paint ordered and as a guide I gave them the fresh air intake scoop to match the old red paint.
Will see how that works out.
Greetings, Harold
1132021benz
  • USA, VT, Burlington
« Reply #21 on: February 06, 2022, 21:41:51 »
If you look at the grommets that are inside the engine bay, along the inner edge of the fender, they appear to have red paint on them.  If so, that indicates prior paint work…
« Reply #22 on: February 06, 2022, 21:45:51 »
Not saying if the car was prayed here or there - I do not know, but these grommets were red when the car left factory. Fairly faded and uneven look of the paint would suggest they stayed original IMHO...
hbrand
  • Edgewater
« Reply #23 on: February 07, 2022, 21:06:42 »
The only painting inside engine compartment where paint brushed underneath the brake booster.
Will post pictures of the painted hood and trunk. Next month
Greetings, Harold
1132021benz
« Reply #24 on: February 09, 2022, 03:21:33 »
With great respect, if you are suggesting that Mercedes-Benz in the 1960’s would install rubber grommets prior to painting a car, I would respectfully disagree.  The shells were painted, then everything else was installed afterwards.  Especially grommets, which would have been among the last installed.   They would not have been painted- paint would make the rubber inflexible…
