Author Topic: Bracket for brake lines  (Read 2679 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: December 20, 2021, 18:20:53 »
Hi to all
I have a strange system to fix the rear brake line and couldn’t find the OEM fixture system. I guess it’s about metallic clamps but still wondering
Anyone to help?
1965 230 SL
1991 Porsche 911/964 carrera 2
1990 Porsche 911/964 carrera 4 SOLD
2020 Harley Davidson Fatboy
2018 Harley Davidson Street Bob SOLD
2003 Harley Davidson Road King Classic SOLD
2017 Harley Davidson softail Slim SOLD
2008 Harley Davidson Softail Fatboy SOLD
My youtube channel #lfgdf
Leester
  • USA, VA, Lorton
Re: Bracket for brake lines
« Reply #1 on: December 20, 2021, 20:08:58 »
Not sure of the correct name for these clamps. They are sort of a "wind up" clamp with two parts, a band and a clamp that rolls the band tight.  Perhaps someone who knows the correct names for these parts can weigh in. I'm sure most of the suppliers have these and I believe there is a section in the Technical Manual that explains the clamps and how to install.  Hope this helps, Lee
Lee Backus
1963 220SE Cabriolet
« Reply #2 on: December 20, 2021, 21:00:32 »
Here is some info and they are available from all the regular MB suppliers.
https://www.sl113.org/forums/index.php?topic=1461.msg7410#msg7410
« Reply #3 on: December 20, 2021, 21:37:05 »
They are generic parts, not specific to Mercedes but available also at Mercedes:
N 900262 009100 binder
N 900263 009000 strap, 2x285mm needed, ordered by meter
9mm width if I remember correctly (probably can be decoded from the DIN number). I think you can buy it in a lot of automotive stores.
I am enclosing a little sketch from 190SL knowledge bank. Not exactly the same perhaps, but showing the idea.
I would buy a couple of more if you are not fluent in installing them. Based on my experience... I was sure i would start binding in the wrong direction and I did.
« Last Edit: December 20, 2021, 22:17:03 by Pawel66 »
« Reply #4 on: December 20, 2021, 22:13:51 »
It's important to note the correct routing of the metal brake pipe. It should run along the BACK of the axle, not the top, so as not to get crushed between the axle and the bump stop in case of maximum suspension deflection.
Figoulu
« Reply #5 on: December 21, 2021, 00:00:59 »
Thanks to all once again 👍👍👍
1965 230 SL
« Reply #6 on: December 22, 2021, 08:41:21 »
For those of us who are old enough to remember the old sardine cans,  we call them "sardine can style" clamps.
« Last Edit: January 14, 2022, 04:47:05 by ja17 »
Leester
  • USA, VA, Lorton
« Reply #7 on: December 22, 2021, 21:02:20 »
I knew someone would know the correct technical name for those clamps.
Lee Backus
« Reply #8 on: December 23, 2021, 14:12:39 »
YES! Rear side of the axle.  In your photo you can see a mark on the axle where the old brake line was clamped.
Joyeux Noël!
« Reply #9 on: January 03, 2022, 11:00:16 »
The inboard one holds the parking brake cable and If I am not mistaken should be painted black.  The outboard one holds the brake line and should be silver zinc.
I just realized Leester's photo shows the inner clamp painted as it should be.
« Last Edit: January 15, 2022, 01:39:49 by Shvegel »
