Author Topic: Pressure in the coolant tank  (Read 2774 times)
bayleif
« on: May 17, 2005, 15:23:05 »
Hi All:
I was checking coolant level this morning and I was surprized that when I took the cap off that it had been under pressure. I haven't driven the car in about a week so it was room temp. Is this normal?
Chuck Bartlett
1969 Signal Red 4 Speed
CarlG
Re: Pressure in the coolant tank
« Reply #1 on: May 17, 2005, 15:29:50 »
I don't know if it is normal, but mine did exactly the same thing yesterday when I checked it under the same conditions.  The coolant level was a little low, but the tank bottom was covered.
1967 230sl (stick)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #2 on: May 17, 2005, 16:01:18 »
Indicates you have good caps.  I'd call it normal.  If it was cold when you added your coolant, or when you last opened the cap, there's probably a bit of pressure just because it isn't near freezing now.
'68 280SL 4-spd Coupe
