Author Topic: Heat shield rear exhaust  (Read 3486 times)
dirkbalter
  • USA, CA, Corona
« on: December 27, 2021, 19:22:15 »
All,
I was about to fabricate or order the rear heat shield for exhaust when I recognized that according to the SLS web-side, it was discontinued in 67. Can you confirm that the 67 and later sl's don't have it and that it is not really needed?
Thank you
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/49-a-exhaust-system-standard/heat-prot-shield-rr-silencer-p-5364
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: Heat shield rear exhaust
« Reply #1 on: December 27, 2021, 21:10:36 »
New topic to me! I have this plate in 280SL (I think it makes a lot of sense). What I see in parts lists:
1. It is not present on any drawings
2. When you get to 113042 exhaust parts list you can find A 113 490 02 30 PROTECTIVE PLATE
LUGGAGE COMPARTMENT, which is this plate, I think.
3. It is present until chassis 042 015659 and then it is gone...
Looks like the truth what they say...
dirkbalter
  • USA, CA, Corona
« Reply #2 on: December 27, 2021, 21:17:23 »
Pawel,
So theoretically you shouldn't have it, right?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: December 27, 2021, 21:20:36 »
To my surprise, after the chassis number I stated - right, you should not have it...
WRe
« Reply #5 on: December 28, 2021, 10:06:30 »
WRe, yes, saw it, I was verifying this info in the EPC.
By the way: another example of different content in German and English on SLS pages. I really need to develop a habit of always looking at SLS pages in German.
WRe
dirkbalter
  • USA, CA, Corona
« Reply #7 on: December 28, 2021, 16:18:58 »
Thanks to both of you. Based on the Niemoeller info, mine did not have one.
Looking at the prices, especially the home made one from Buds Benz, for a plain piece of bend sheet metal, I will stay original at that point.
Wish you a happy new year.
« Last Edit: December 28, 2021, 17:20:47 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #8 on: December 28, 2021, 19:27:00 »
My early 230 from 03/64 has it. I fabricated a new one. See pic for dimensions if you wat to make one yourself.
1964 230SL
« Reply #9 on: December 28, 2021, 19:40:29 »
Nice! Thanks for posting those dimensions Sead, it looks fairly easy to make (so long as you have a bead roller and a rivet tool that is) but you do need those dimensions, so thanks for that.
dirkbalter
  • USA, CA, Corona
« Reply #10 on: December 28, 2021, 19:53:53 »
Sead,
Thank you.
That’s perfect. Couldn’t ask for more. Now I am tempted to make one again.
Did you use aluminum or steel?
« Last Edit: December 28, 2021, 20:02:58 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sead
« Reply #11 on: December 28, 2021, 20:10:32 »
Sead,
Thank you.
u r welcome.
You have to use aluminum of course. 1,5mm
Regards
Sead
1964 230SL
Chris Long
  • USA, NJ, Morristown
1970 280sl 4-Speed Horizon Blue
Sead
« Reply #13 on: January 19, 2022, 10:56:35 »
https://www.authenticclassics.com/Exhaust-Heat-Shield-under-Trunk-230SL-250SL-280SL-p/auth-004712.htm
Available here to...
These reproductions  do not quite correspond to the original form. Vertical side is getting narrower toward back plus a pice at the front must be cut off. See my part. But that can be done at your own...
1964 230SL
dirkbalter
  • USA, CA, Corona
« Reply #14 on: January 19, 2022, 16:59:30 »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sead
« Reply #15 on: January 19, 2022, 17:15:16 »
Yup, even worse imo are the once offered by Buds Benz.
https://www.budsbenz.com/catalog/230-250-280-sl/g-exhaust-parts-intake-system/G208-003
what a crap all of them... :-[
Front one I made myself too. The big one bought at mbclassic.de
1964 230SL
DaveB
« Reply #17 on: January 20, 2022, 01:30:23 »
Yes, Bad - looks like a high school project.
Sead's and SLS' look nice.
DaveB
'65 US 230sl 4-speed, DB190
roymil
« Reply #18 on: February 15, 2022, 18:55:42 »
Whichever quality version is chosen, and whatever year the car, I can highly recommend using some kind of rear exhaust heat shield, especially for those living in hot climates.   That shield deflects a lot of heat away from the fuel tank.   After some exhaust work mistakenly omitted the shields many years ago (thanks dad :-), I do well remember frequent fuel odors from an overheated tank's vapor pressurizing past the filler cap, especially when sitting with no airflow just after a drive on a hot summer day with a full tank.  Fuel can expand 2-3% from a cool morning to a 115F desert afternoon, more when you add in the exhaust heat next door.  Maybe most cars lived in nice climates and Mercedes cost-cutters thought they could delete that shield at some point, but if you ever notice the odors and you know the cap and fuel lines are good, then this shield might help.   Another way to tell is from the paint around the filler that can eventually become cloudy and brittle after repeated fuel vapor exposure.   Adding the shield back is fairly easy and didn't require removing the whole exhaust, just removing rear mountings and pulling it down enough to slide in.  Hope that helps someone.  Best regards, Mark
Mark Miller
1968 280SL
« Reply #19 on: February 15, 2022, 21:51:09 »
We were making the center heat shield a few years ago but didn't get a lot of interest at the time. Still have the buck to make them from .050'' aluminum. These are exact copies of the original.
