Author Topic: Blower Fan removal  (Read 1473 times)
230slhouston
Blower Fan removal
« on: December 28, 2021, 05:46:59 »
Wanted to share a hack I made to remove the blower impellers using a puller avoids using hammers.
I welded three nuts to a washer and locked this against the collar.
A-9294
  • Norway, Oslo, Oslo
Re: Blower Fan removal
« Reply #1 on: January 23, 2022, 13:11:26 »
Hi, 230slhouston.
I am curious - On mine blower it was a small lock screw (Allen key/Hex key) on the metal part of the fan impellers. Loosening this, and the impellers was just to pull out easily... Was the Allen key "rounded" / unusable in your case? As you may noticed the small Allen key is fastened to a flat spot one the fan motor axle. How did you get the small screw over the not flattened end part of the axle?
Regards
Jan L-S
'65 W113 230 SL
'62 Series 2a 88" Land Rover
'07 Discovery 3
'20 Renault Zoe
'76 Honda CB 500 four
'95 Yamaha YZF 750R
'96 Yamaha GTS 1000
'12 BMW K1600 GTL
230slhouston
« Reply #2 on: January 25, 2022, 02:42:16 »
I am not sure if I understand the question.  But I unscrewed the screw and removed it first.  Then removed the impellers. When I install, just put it in one turn before installing the impellers over the shaft.
Hope this helps.
