Author Topic: Standing water in rear valence  (Read 1706 times)
Andrew Leach
  • United Kingdom, England, Oxted
  • 1968 280SL
« on: December 28, 2021, 22:49:21 »
Hello everyone,
10 months ago, I purchased a 280SL that has been extensively restored.  A few weeks ago, I got caught in a tremendous downpour and noticed a large puddle of water in the boot (trunk).  I subsequently traced this to faulty tail-light seals, which I've now replaced.  However when doing this job I removed the two rear steel cover plates, that provide access to the number plate lamps and noticed standing water (about 1cm) at the bottom of this compartment  - where the rear valence joins the body.  I can't see how the water made its way into this area.  Should there be drain holes in this section?  I haven't seen any reference to these in the posts about water leaks. Any thoughts would be most welcome.
Re: Standing water in rear valence
« Reply #1 on: December 29, 2021, 00:38:40 »
Not aware of a drain hole there...
First thought on source of water - type designation holes and/or "Automatic" sign holes - do you have them sealed?
« Reply #2 on: December 29, 2021, 04:29:19 »
Also just check where the number plate screws enter the rear panel they may also allow water to enter that cavity.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Andrew Leach
  • 1968 280SL
« Reply #3 on: December 29, 2021, 20:57:50 »
Hi - thanks for the advice.  Will take a look.  There's a small hole in the floor of the boot.  I think water must have dripped in from the tail lights, then found its way into this cavity, perhaps through this hole in the boot floor.  I've syphoned as much as I can and sprayed a load of wax into the cavity, so I hope that'll hold the rust at bay, but it's something to keep an eye on.
