Author Topic: Heater valve linkage  (Read 2005 times)
EeVeeWee
« on: December 29, 2021, 15:34:36 »
I'm very glad with this Pagoda SL Group, because there is so much information to be found!
Does anybody know the length of the heater valve linkage rod in this picture?
I know the air valve was broken when I bought the car, but I can't remember even if this linkage was present.
I found two linkage rods, but one seems longer and one shorter than the one at the picture.
Again something else.
Re: Heater valve linkage
« Reply #1 on: December 29, 2021, 16:28:48 »
The rod length should be adjusted once all the components are mounted in the car. The length is set so that the water valve is off when the flap is completely closed.
EeVeeWee
« Reply #2 on: December 29, 2021, 18:14:21 »
Yes of course, that I understand.
But how long is the M5 threaded rod with left and right threads?
WRe
« Reply #3 on: December 30, 2021, 07:40:13 »
afaik the rod is ~7,5 cm from center to center of the ball heads.
...WRe
EeVeeWee
« Reply #4 on: December 30, 2021, 09:40:45 »
...WRe
OK thank you, I can use this to find the right rod.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: December 30, 2021, 21:03:22 »
This is the rod that came of mine. 2x right hand thread 45mm lg.
Center to center approx 76mm
« Last Edit: December 31, 2021, 16:46:26 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
EeVeeWee
« Reply #6 on: December 31, 2021, 11:41:26 »
Thank you, that is an alternative I also made.
The center to center length can be fixed just once, but after that it should never been adjusted again.  ;D
EeVeeWee
« Reply #7 on: December 31, 2021, 15:19:09 »
Installed and functioning, thank you all!
TJMart
  • USA, NC, Matthews
« Reply #8 on: December 31, 2021, 15:44:01 »
Great job and thanks for the pics for those of us that will eventually need to do it in the future.
Tony
1970 280SL, 4 Speed
A-9294
  • Norway, Oslo, Oslo
« Reply #9 on: January 23, 2022, 13:17:06 »
My rod was gone as well - Spot on information ;D THX guys!
Regards
Jan L-S
'65 W113 230 SL
'62 Series 2a 88" Land Rover
'07 Discovery 3
'20 Renault Zoe
'76 Honda CB 500 four
'95 Yamaha YZF 750R
'96 Yamaha GTS 1000
'12 BMW K1600 GTL
