Author Topic: Short Fuel Pump Rebuild Issues  (Read 6870 times)
Kevkeller
  • USA, HI, Honolulu
« on: December 30, 2021, 09:43:02 »
I had an old pump I wanted to rebuild after my rotor overheated and the plastic melted. I was able to get a rebuild kit including a new rotor from Vintage Euro Parts.
One of the issues I had was that one of the  brush holders had broken off. With a little help from Bob Youngman I was able to fix it. Maybe this will help someone else.
There is a fiber plate that the brush holders attach to. Each holder has two small tabs that go through holes in the plate which crimp to the plate. My tabs had broken. The fiber plate is mounted to the pump frame on two posts that each have a washer that is held on by peening the post top.
The first thing I did was to use a boring head on my mill to remove the peening on the post. This allowed me to pry up the washers. The first came off nicely but the boring bar slipped on the second which cracked off the top of the post.
I was then able to pull off the fiber plate. I spent a while trying to figure out how to remount the brush holder because there isn’t much room to attach anything. I decided to make copper rivets from 14 gauge copper wire. I used a number 51 drill on a block of metal. I would slip the wire in the hole and cut off the wire maybe 3/16” then peen the 3/16” bit to make a head. It didn’t look beautiful but works great. I drilled new holes through the fiber plate for the rivets. The brush holder was remounted and the rivet peened on the other side.
You have to be careful about the bottom of the rivet not touching the metal pump case otherwise it’ll short. There is a cutout below where the brush tabs crimp to prevent shorting but you still need to keep the rivet head small and flat. I had to grind part of it away to keep it from shorting.
The fiber plate was reinstalled. I got the washer on the good post and peened. As for the other post I thought about drilling and threading a screw but the plate was in pretty tight and shouldn’t move so I left it alone.
Another issue I came upon was a leaking check valve that lets the air out of the pump case. I opened it up and removed the caked on sediment to the plastic valve and the metal seat.
After putting the pump together my outlet check valve wasn’t sealing either. So I put it on my lathe and cut out the aluminum seat.  I took the plastic valve plate and sanded it smooth. You can see all of the sediment left on the remains of the cut valve seat. I’m not sure if I could have removed that by soaking or using a ultrasonic cleaner. I’m in the process of making a new aluminum seat for the valve.  I’ll show a picture after I’m done .
« Last Edit: January 08, 2022, 08:37:47 by Kevkeller »
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
Re: Short Pump Rebuild Issues
« Reply #1 on: December 30, 2021, 09:47:00 »
More pics.
« Last Edit: December 30, 2021, 09:55:10 by Kevkeller »
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
« Reply #2 on: December 30, 2021, 09:52:21 »
More.
« Last Edit: December 30, 2021, 10:27:28 by Kevkeller »
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
« Reply #3 on: December 30, 2021, 10:01:02 »
More.
The 3rd picture is what’s left of the fuel pump discharge check valve seat I cut out.  It wasn’t going to seal in that condition.
I probably should have tried cleaning with an ultrasonic cleaner first.
« Last Edit: January 06, 2022, 07:35:24 by Kevkeller »
1970 280 SL
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #4 on: January 03, 2022, 22:01:52 »
Excellent work
Bob "Baron" Youngman
1965 220se coupe restomod
Kevkeller
  • USA, HI, Honolulu
« Reply #5 on: January 04, 2022, 03:06:50 »
Thank you Bob.
I guess there is a small spring in the fuel pump discharge check valve. I never saw it and must have lost it. I ordered some copper spring wire .010” to make a new one.
Hopefully that’ll get the valve working again.
« Last Edit: April 24, 2022, 16:18:53 by Kevkeller »
1970 280 SL
« Reply #6 on: January 04, 2022, 13:04:14 »
Nice, a mill is one of those bulky tools that I can never justify owning due to space/cost/number of times used but they certainly do come in handy!
Kevkeller
  • USA, HI, Honolulu
« Reply #7 on: January 04, 2022, 15:52:30 »
It does take up room but between that and a lathe they’ve paid for themselves many times over. They also make unique tools that I need to fix the Mercedes.  I made several tools to work on the power steering, fuel injection pump, suspension, etc.
I’d hate not to have one. In addition I have a small Sherline lathe and mill which would have done the job also. They’ll fit in a very small area. I recently bought a 15 m wood schooner in Honfleur France I plan on sailing to Florida. I wouldn’t mind bringing a Sherline lathe/mill just in case. You never know when one can save the day.
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
« Reply #8 on: January 06, 2022, 07:20:40 »
I have another old pump I am rebuilding also. This one had a rotor commutator in very worn condition. I used the lathe to turn the commutator down to a smooth surface again.
« Last Edit: January 06, 2022, 07:37:38 by Kevkeller »
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
« Reply #9 on: January 06, 2022, 07:31:50 »
The copper commutator tends to smear so you have to scrape out the lands between each one. I used a lathe cutter and slid it horizontally across the commutator. Then I ground a hack saw blade to clean up the lands by hand.
1970 280 SL
« Reply #10 on: January 06, 2022, 07:47:20 »
What you've shown above is an important step when cleaning up a commutator.
« Reply #11 on: January 06, 2022, 11:54:34 »
Love this!  ;D
Kevkeller
  • USA, HI, Honolulu
« Reply #12 on: January 06, 2022, 21:55:33 »
The Rose de Savannah
1970 280 SL
« Reply #13 on: January 06, 2022, 22:36:47 »
Beautiful!
Kevkeller
  • USA, HI, Honolulu
« Reply #14 on: January 08, 2022, 03:33:15 »
Never thought I’d buy a 15 meter wooden schooner on the other side of the earth from where I live but I did. It’s is beautiful.  Looking forward to some good times sailing Florida and the Caribbean.
Believe it or not I never stepped foot on it. But it’s in top shape.
1970 280 SL
yves
  • France, Poitou-Charentes
Re: Short Fuel Pump Rebuild Issues
« Reply #15 on: January 08, 2022, 13:28:51 »
If you want a nice stop before crossing the "pound" you are welcome in LA ROCHELLE  ...!
Kevkeller
  • USA, HI, Honolulu
« Reply #16 on: January 08, 2022, 17:48:44 »
Thank you. I’ll keep that in mind!
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
« Reply #17 on: January 09, 2022, 01:35:29 »
Back to the pump.
Just finished the discharge check valve. I made the spring.  The picture was a practice spring.
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
« Reply #18 on: January 09, 2022, 01:41:45 »
The spring came out about perfect. It was comparable to the other check valve I have.
Came out very nice.
« Last Edit: January 09, 2022, 02:00:36 by Kevkeller »
1970 280 SL
h100vw
« Reply #19 on: January 24, 2022, 09:31:48 »
Looks good all finished up! Kev
Have you applied power to it yet? I just rebuilt one the same. Had some dramas to get around but not like yours.
I feel the impeller is a tiny bit too thick for the casing, when I do up the cover screws all the way it doesn't turn. If I back them all off half a turn or so, it runs fine. No leaks but it doesn't sit right with me that they aren't done up.
I'm going to take it apart again and see if the original one is better. If not I'll use some wet or dry and rub it down on a piece of glass.
Anyone had this experience?
Kevkeller
  • USA, HI, Honolulu
« Reply #20 on: January 24, 2022, 10:51:28 »
I’ve run the pump dry with some 30w oil lubricant and it seems to turn ok. I think it does turn a slight bit slower when tightened but I’m thinking with gas it’ll run ok.
I do plan on running some diesel through it sometime when I get a chance.
I bought an extra impeller if I remember I’ll measure the thickness.  The only problem I had with one was it was too tight on the shaft. I filed it with a needle file slightly.
1970 280 SL
mistertj
  • USA, FL, Satellite Beach
« Reply #21 on: April 23, 2022, 19:05:22 »
I'm having a similar issue with the brush holders and wondering if something like a JB Weld or super glue would work to hod the brush holders in place?
mistertj
« Reply #22 on: April 23, 2022, 19:31:00 »
Just saw your post on the sticking fuel pump impeller. Had a similar problem years ago. Had taken my pump apart to "check" things out. When I put back together and applied power at the bench...got a spark but no rotation. Took apart and put some 400 grit wet sandpaper on a flat metal place. worked each side for 2 to 3 minutes and then did same to the bottom plate. Cleaned everything up, oiled and reassembled with a new O ring. Ran fine! It may have just been a tired O ring but what ever it was...it fixed it.
Kevkeller
  • USA, HI, Honolulu
« Reply #23 on: April 23, 2022, 19:37:15 »
I don’t know personally but I think Bob Youngman said that JB Weld might eventually fail. Maybe if you got it through the hole and it flared out on either side.
I did contemplate making a new brush holder from a sheet of copper. It wouldn’t have to be the exact carbon copy.
If you’d like I could try shaving off the sides of the top of the hold down rivets so you can take off the plate and try to copper rivet the brush holder back in like I did. Then peen the plate holder mounts.
Kevin
« Last Edit: April 24, 2022, 07:20:08 by Kevkeller »
1970 280 SL
mistertj
« Reply #24 on: April 23, 2022, 20:34:28 »
Hi Kevin - Thank you for responding. The brush holders are still holding in place but they rock enough so that I can get a small screw driver tip underneath as can be seen in one of the photos. With that in mind, was thinking that it wouldn't need much more to hold the front of the brush holders down and thus the JB Weld thought. Since you took your brush holder plate out, what on the other side? Is it just a couple of brush holder tabs that are bent over to hold things in place?
The other idea I was toying with is to drill a small hole in the middle of each post and then try to crush the post enough to get the washers off. If that worked, could just re-peen the posts when putting things back together.
Anyway, I've put a little dab of JB Weld on the phenolic plate that the brush holders are mounted on to see how good it adheres. We'll see. Appreciate your input. Thank you.
