Author Topic: Short Fuel Pump Rebuild Issues  (Read 4739 times)
mistertj
  • USA, FL, Satellite Beach
Re: Short Fuel Pump Rebuild Issues
« Reply #25 on: April 23, 2022, 20:50:45 »
What diameter would you guess the posts might be?
Kevkeller
  • USA, HI, Honolulu
« Reply #26 on: April 23, 2022, 20:58:14 »
Yes they are bent tabs. I would probably guess your tab was broken like mine was. Here is a picture of the back of the plate.
If you zoom in you can see one side with the originals and the other side with the rivets I made.
1970 280 SL
Kevkeller
  • USA, HI, Honolulu
« Reply #27 on: April 23, 2022, 21:02:22 »
If you’re talking about the posts that hold the plate down I’m guessing 3/16”-1/4” maybe.
You can see them in one of the earlier pictures.
1970 280 SL
mistertj
« Reply #28 on: April 28, 2022, 14:30:50 »
Hi Kevin - Got the brush plate off by cutting into the washers on the posts with a cutting disk and Dremel tool. Once the plate was off, drilled a hole in the center of the posts and threaded with 3.05 tap. The photos tell the story. Will put some Loctite on the threads when I reassemble. Oh yes, bent the brush holder tabs so they are tight again. Success!
Kevkeller
  • USA, HI, Honolulu
« Reply #29 on: April 28, 2022, 15:03:41 »
Nicely done. Saved another pump and $1000++.
Just looking at the picture with the screws in it. You might want to try to get different head screws so the brush coil wire doesn’t touch them.
« Last Edit: April 28, 2022, 15:30:06 by Kevkeller »
1970 280 SL
