Please check out joining the
Emergency Contact List
for help during your travels!
Noise and Vibration comes and goes while driving?
Topic: Noise and Vibration comes and goes while driving? (Read 1615 times)
petesman
December 30, 2021, 14:37:44 »
I have owned by 280sl for 15 years and this has never happened before. Car is responding fine----and then it starts vibrating and making almost like a "rubbing noise"----and disappears? This cannot be good. Any help would be appreciated.----peter
Full Member
Platinum
USA, CA, Fallbrook
Re: Noise and Vibration comes and goes while driving?
December 30, 2021, 14:40:33 »
I would look at the driveshaft bearings and universal joints. And the differential mounts. Don't drive the car until you have found and corrected the issue.
Full Member
Platinum
USA, VA, Blue Grass
Reply #2 on:
December 30, 2021, 21:41:33 »
Check the rubber rotoflex coupling between the transmission and the driveshaft. The rubber will perish over time. Not fun if it lets go!
- Mike Hughes -ô¿ô-
