Author Topic: Manual gearbox replacement  (Read 2445 times)
BRDownes
« on: January 06, 2022, 06:58:51 »
I want to replace my 4 speed manual gearbox with a 5/6 speed manual gearbox on my 1971 RHD 280sl. Purpose is to reduce the revs for higher road speed. I have approached the SL Shop in UK and they have a conversion kit which includes parts for the conversion from automatic to manual. They say that converting a manual to a 6 speed will require the full kit and do not split the kit, but this does not make sense because my car is a manual. The kit also highlights with an asterix those parts for the auto conversion not required for the manual conversion. However, they will only sell the complete kit.
Does anyone know of another supplier from where I can get a 5/6 speed gearbox to convert my 4 speed manual?
707dieseldean
  • USA, CA, Santa Rosa
Re: Manual gearbox replacement
« Reply #1 on: January 06, 2022, 18:47:40 »
These folks seem to be the only viable option at this time. Buds Benz is not doing the "Raymond" 5 speed set up at this time. The Polish 6 speed is too much for our cars!
https://drivenman.com/product/mercedes-280sl-5-speed-conversion-kit/
Kit runs about 5k USD. The nice part is the base transmission has global parts availability. You also have the option of choosing the overdrive gear from .73 or .63
69 280SL / Manual 4 speed
 904 - Lower Midnight Blue
 158 - Upper White/Grey
 145- Vellum Interior
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
« Reply #2 on: January 06, 2022, 19:40:36 »
I don't know if I would build it into a pagoda. Which gear is it? It all looks a little wrong. Peter
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
707dieseldean
« Reply #3 on: January 06, 2022, 19:56:07 »
I believe that the base transmission is a Tremec T5.
gordon
  • United Kingdom, England, Burntwood
« Reply #4 on: January 10, 2022, 21:06:57 »
There are lots of previous posts on fitting a Getrag 5 speed gearbox in a Pagoda, ( as fitted to Jaguar, BMW and GM ) If you want a reconditioned box with mechanical speedo drive let me know.
Gordon (UK)
lagolag
  • Sweden, Västra Götaland, Askim
« Reply #5 on: January 11, 2022, 16:25:55 »
I'm on the same route.
Check www.w113.org (German), from here you can get all you need for installing a 5 speed Getrag 265/6.
https://w113.eu/Shop/Roadbook%20Shop.html Google translate works well.
The gearbox, Getrag 265/6, can be found att Breakers, many available in Germany.
There is several earlier treads in this matter on this site, but they are a bit out of date.
I have got the gearbox, installation kit and the needed shafts, waiting for a Bell house to keep the original gearbox intact.
So I'm about to start the job.
230SL 1967 since July 2021
SL55 AMG 2003 since July 2008
Suzuki Cappuccino 1995 since May 2006, Sold
NewToW113
  • USA, MA, Newton
« Reply #6 on: January 12, 2022, 19:42:06 »
I was thinking about a conversion for my 230 4sp for the same reason,
I was thinking about this one:
http://www.2040-parts.com/new-6-speed-manual-transmission-gearbox-for-mercedes-230sl-250sl-280sl-pagoda-i1646448/
The seller claims no mods are needed although I have heard that maybe tunnel work needs to be done on the 230 cars.  Is this what you guys are referring to as the polish one?
Seems like the ratios are close to the stock 5 speed, I agree 6 is too high (esp for my 230) but then again you wouldn't have to use it?
1967 230SL Euro 4spd WIP
1976 Porsche 911S Euro 3.0
Chris Long
  • USA, NJ, Morristown
« Reply #7 on: January 19, 2022, 14:06:46 »
I'm doing the conversion currently - the kits (mrfiat, 2040, SLS etc) are actually from the same supplier based in Poland/Germany - Anna Thom.
You can buy directly from them - please feel free to contact me if you want more info. rgds
1970 280sl 4-Speed Horizon Blue
chuen teck
  • Singapore, Central Singapore, Singapore
« Reply #8 on: April 04, 2022, 02:43:44 »
Hi Chris,
can you please email me the contact details for Poland/Germany - Anna Thom.
chuenteck@hotmail.com
Chris Long
« Reply #9 on: April 06, 2022, 16:58:27 »
Emailed - FYI looks like i received a bad box; First gear didn't work so trying to get a replacement from them... Will advise on how that process goes.
