Author Topic: The Plan for Today Was...  (Read 2094 times)
« on: January 14, 2022, 20:48:07 »
The Plan for today was to install overhauled alternator...
zak
  • USA, NJ, Bernardsville
Re: The Plan for Today Was...
« Reply #1 on: January 17, 2022, 21:05:17 »
And you successfully completed the job, right ?
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
« Reply #2 on: January 17, 2022, 21:20:12 »
Well, what you see on the floor is current status...
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #3 on: January 17, 2022, 21:39:38 »
Pawel, it is a good plan to have all the parts and tools in order, so I say you had a successful day tomorrow is another day :) right ... right
Dieter
« Reply #4 on: January 17, 2022, 22:17:06 »
That is right!
I had alternator out. It came back. I said - let's just take a look if there are no leaks, etc. before install and let's check if the PS pump is tight after last year removal. There we were...  radiator, water pump, PS pump bolt damaged, as the fan was out - let' s refresh it... i also have doors disassembled for shifters repair, soft top disassembled for V elbow elimination... the car is in pieces.
