Author Topic: Wanted  (Read 4390 times)
gordon
  • United Kingdom, England, Burntwood
Wanted
« on: January 17, 2022, 13:58:12 »
Wanted, both springs which lift up both the boot lid and the soft top cover. (The previous owner cut off one end of each spring presumably to remove them)
Dave H
  • United Kingdom, England, Durham
    • Dave H
Re: Wanted
« Reply #1 on: January 17, 2022, 16:15:39 »
One of my least favourite jobs of the whole restoration, unbelievable amount of tension in these springs, I foolishly took them off and damaged my new paintwork when refitting , some threads on how to refit and special tool to make if you search this site, I don’t envy you.
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
Re: Wanted
« Reply #3 on: January 18, 2022, 09:30:07 »
Be advised that they are different for California Coupe.
gordon
Re: Wanted
« Reply #4 on: January 18, 2022, 19:52:49 »
Thanks for all input. I have both springs ( but with one end cut off) if I could copy an intact set I'd make the missing bits (tempered) then sleeve onto what I have.. At least replacement s are available at a cost !
Re: Wanted
« Reply #5 on: January 19, 2022, 09:57:50 »
I'm intrigued to know the process for repairing a failed (or cut) torsion spring.
Re: Wanted
« Reply #6 on: January 19, 2022, 11:21:41 »
And also why do it - I would have thought there are quite strong and dangerous forces applied...
Pinder
  • USA, NJ, Edison
Re: Wanted
« Reply #7 on: January 19, 2022, 15:52:10 »
I dont know if it helps but i removed them and likely will install in the same way by screwing in sheet rock screws at several points along the spring to lengthen it. while removing or installing.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
