Author Topic: Battery to starter cable length SL230 RHD Auto  (Read 1698 times)
Esmo
  • United Kingdom, Wales, Conwy
  • SL 230 1967
« on: January 22, 2022, 13:40:45 »
Hi I see this question has been asked previously but cannot find a definitive answer . Three sizes are advertised
SLS show 1570 mm Long and 1480mm short also 1650 is mentioned in previous answers . I would like to fit the correct one see above . Your help would be appreciated .
BobH
Re: Battery to starter cable length SL230 RHD Auto
« Reply #1 on: January 22, 2022, 14:29:46 »
Pawel wrote:
"As per SLS there are longer ones, for later cars, 157cm and shorter ones for 230SL, 147cm.
https://www.sls-hh-shop.de/main/en/54-elektrical-equipment-at-body-54equipment-for-cable-harness-c-3_2339_83
I ordered the longer one for 280SL and it fit ok. Always better to have longer than shorter...
If you are buying the wire to make it yourself, I noticed it is quite important the it is made of thin threads so that even though it is a thick piece of wire, it is soft and easy to shape"
The SLS listing says the shorter cable (1480mm) is for the 230
« Last Edit: January 22, 2022, 15:02:30 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #2 on: January 22, 2022, 18:14:15 »
I may add, I have just looked through the parts list in the EPC:
- no LHD/RHD designations for positive cable part number
- funny enough - part number for 113042 and 113044 are the same
The difference in length is per SLS only.
I agree, it is better to be rich and beautiful than poor and ugly.
The differences LHD/RHD in parts numbers are for the brackets/positive cable routing.
